		wreining(at)gmail.com Guest
				 Posted: Fri Mar 09, 2007 5:17 pm    Post subject: Avery's Rudder Cable Fairings: Installation on Tailcone |
				Do we need to wait to attach these fairings until after the rudder cable is inserted?  I don’t know how large the end of the cable is.  I’d just as soon rivet the fairings on now, before we attach the skins.  Reading the archives, I see where some folks have installed nut plates – that would obviously avoid the issue.  But still, why not just rivet them on now, if the cable will pass through later?  Any advice would be appreciated.  Thanks.
 Bill (and Jon) Reining
 40514 tailcone
		bob.kaufmann(at)cox.net Guest
				 Posted: Fri Mar 09, 2007 5:45 pm    Post subject: Avery's Rudder Cable Fairings: Installation on Tailcone |
				The rudder cables will not go through with them riveted on.  Don’t ask me how I know.
 Bob K
 Fiberglass and panel
 From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Bill Reining
  Sent: Friday, March 09, 2007 5:17 PM
  Subject: Avery's Rudder Cable Fairings: Installation on Tailcone
 40514 tailcone   	  | Quote: | 	 		  |   http://www.matronics.com/Navigator?RV10-List  | 	  01234
				 Posted: Fri Mar 09, 2007 6:19 pm    Post subject: Avery's Rudder Cable Fairings: Installation on Tailcone |
				It depends on how far back you put them.  If you put them a little forward of the rear of the hole, you can still get them in.  I don’t know that they help any on drag, but they look good.  You want to have the tube that is on the cable sticking out far enough so the cable doesn’t touch metal when it moves (there was a plane at OSH this year that has a good groove cut in the skin from the cable rubbing).  It is better to install it with nutplates for a good tight fit, but if you rivet it you can fill around it and the edge will disappear.  Just leave it far enough forward that you can get the cable through, is my suggestion.  Again, it is for looks more than anything, IMHO.
 Jesse Saint
 Saint Aviation, Inc.
 www.saintaviation.com
 Cell: 352-427-0285
 Fax: 815-377-3694
 From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of bob.kaufmann
  Sent: Friday, March 09, 2007 8:45 PM
  Subject: RE: Avery's Rudder Cable Fairings: Installation on Tailcone
 Bob K
 40514 tailcone  [/b]http://www.matronics.com/Navigator?RV10-Listhttp://forums.matronics.com[/b][quote][b]    [b]
