Posted: Thu Mar 08, 2007 3:50 pm Post subject: Aircraft Extras FPS plus |
Hey all -
on the subject of flap positioning units, I was looking at the aircraft
extras FPS plus, and wondered if more experienced pilots could weigh in
for me. From what I understand, this system allows you to set trim
positions for each flap position, so that when you put the flaps down,
the trim automatically goes to where you want it. so far I get this...
but the explanation on the website says that with the system, when you
put the flaps down, the plane just slows down, without the nose pitching
down. now, I realize that I've only flown cessnas and Cherokees, but
when I put the flaps down, the nose wants to come up. Then it goes
down... I think... if the system adds elevator trim (up) when you put
the flaps down, won't you be fighting the stick excessively for a few
seconds? Or am I a chucklehead? You can tell me - I won't be mad
The website states that with the system you don't have to fight stick
pressures in landing and takeoff phases of flight due to the automatic
trim compensation. What say you all?
cj
#40410
dangerously close to starting the finish kit...
www.perfectlygoodairplane.net
Miles Bowen
Posted: Fri Mar 09, 2007 7:51 am Post subject: Re: Aircraft Extras FPS plus |
cj,
Different airplanes respond differently to flap deployment, but I'm not aware of one that pitches up, then down on its own. My 170 pitches up with flap deployment, then I have to trim down. Cherokees I've flown pitch down with flap deployment and I have to trim up. I have very little RV time, but I think most of them pitch down with flaps, thus the up trim to compensate. Sounds like the automatic trim system would be good once you had it dialed in to your airplane's characteristics.
Miles
HRII, Tanks
RV-10 Looky-Loo
_________________ Miles
1955 C170B
HRII Plans#211 |
owl40188(at)yahoo.com Guest
Posted: Fri Mar 09, 2007 8:57 am Post subject: Aircraft Extras FPS plus |
My experience is that at initial flap deployment usually you get extra lift and a pitch up. As the speed bleeds off due to the extra drag it results in a pitch down. Typically when initially activating flaps I put in a slight nose down input to counteract the effect. This only lasts a few seconds. Following this I use up trim to get the right speed and glidepath.
Niko
40188
millstees(at)ameritech.ne Guest
Posted: Fri Mar 09, 2007 8:58 am Post subject: Aircraft Extras FPS plus |
I just received the FPS system, will be installing soon. The system is
available with/without the trim compensation ( I got it). It does not
matter pitch up or pitch down, you can program either way. I have no
experience with this system, however, I think it will be a real bonanza on a
dark bumpy trip down the ILS.
Steve Mills
RV-10 40486 Slow-build
Naperville, Illinois
finishing fuselage
