dustinp(at)hughes.net Guest
Posted: Wed Mar 07, 2007 5:40 am Post subject: Transponder noise |
After installing my radio stack (GNS 430, SL-40, GTX 330, GMA 340) and
firing it up for the first time, I find that I can hear the ticking
transponder broadcast signal in my headset (as well as on a AM/FM radio that
was turned on in the shop at the time).
I thought my com antennae may be to close to my transponder antenna, but I
can still hear the ticking broadcast even when the com radios are turned
off, and only the audio panel is left on. The ticking stops when the
transponder is placed in standby mode or turned off, so I know that is where
it is coming from.
Thanks for any ideas on how this can be cured?
nuckollsr(at)cox.net Guest
Posted: Wed Mar 07, 2007 10:30 am Post subject: Transponder noise |
At 07:39 AM 3/7/2007 -0600, you wrote:
that was turned on in the shop at the time).
where it is coming from.
| Quote: | Thanks for any ideas on how this can be cured?
While your antagonist and victim have been identified, you
still need to identify the propagation mode. When presented
with your situation, we know that there is a combination
of three things that may eliminate the noise problem or at
least reduce it to unnoticeable levels.
(1) Fix some issue with the antagonist that doesn't
conform to industry practice for integrating
the product into an aircraft.
(2) Fix some issue with the victim that doesn't
(3) Eliminate or attenuate the propagation mode that
brings energy from the antagonist to vulnerable
components of the victim.
When anyone hears a short burst of "buzz" synchronous
with illumination of the transponder REPLY light, 90%
of the time it's an RF detection of the reply pulses
someplace in the audio stream. Obviously, our best
starting assumption is to set actions (1) and (2)
aside. Most of the time, the hardware we install has
been competently designed and tested to live in the
aircraft environment. So let's talk about (3).
What kind of audio panel? What are the connectors
on the back like? Is your airplane composite or
metal? Where is the transponder antenna mounted with
respect to the panel?
Dustin Paulson
Posted: Thu Mar 08, 2007 5:33 am Post subject: Re: Transponder noise |
Bob,
The audio panel is Garmin GMA 340 with 2 large D-sub connetors on the back. I had Approach Systems build the harness for it, as well as all the other avionics, and use their avionics hub to connect everything together.
The plane is a highwing GlaStar, which has chrome molly passenger cage surrounded by a fiberglass fuselage, and vertical stabilizer. It has aluminum wings, rudder, and horizontal stabilizer.
I built a composite battery shelf that spans the fuselage sides behind the bulkhead that seperates the baggage compartment from the empanage. In addition to the battery on one end, the ELT is located on the other end, and the transponder antenna inbetween, with the ground plane mounted on top of the shelf, and the element hanging underneath. This places the antenna about 8 feet behind the panel.
I thought the foil tape marker beacon antenna glassed to the belly of the empanage may be picking up the transponder broadcast since it is hooked directly to the audio panel. So this morning I went out and diconnected the marker beacon coax from its lead on the audio panel harness, while I listened to my headset. However there was no change in the ticking when I diconnected the coax.
I did notice a significant change in the volume of the ticking when my physical position changed as I moved around the plane to make the disconnection. I also noted that when I turned off the ANR on my LightSpeed headset, the ticking was no longer audible, but I really don't want to fly without the ANR since it makes radio transmissions so much easier to hear.
It does seem like there is something in the headset or ANR circuitry that is picking up the transponder transmission. Has anyone else experienced this? and if so did you find a fix??
Dustin Paulson
Posted: Fri Mar 09, 2007 5:55 am Post subject: Transponder noise |
At 05:33 AM 3/8/2007 -0800, you wrote:
<dustinp(at)direcway.com>
Bob,
But it also places the panel and all stuff in the cockpit right in the
antenna's major radiation pattern. I've never been too happy with the
notion of internal transponder antennas. Sticking them out the bottom
of the fuselage offers an opportunity to reduce radiation to the
ship's other systems by a factor of 100 or more.
| Quote: | I thought the foil tape marker beacon antenna glassed to the belly of the
disconnection.
Yup. Your antenna location is filling the cockpit with
RF stresses . . . moving around within the cockpit will
"stir" the pattern of maximum stress.
| Quote: | I also noted that when I turned off the ANR on my LightSpeed headset,
Is the ANR headset specifically for aircraft? It
may or may not be designed to live in the aircraft
radio noise environment. In any case, try moving the
antenna to the belly and put either a tuned (radius
equal to antenna mounted height) or a would-like-
to-be-infinite (as generous as practical) ground
plane over the antenna's mounting location. In this
case, an 'oversized' ground plane goes to the task
of minimizing radiation in the direction of the cabin.
