japhillipsga(at)aol.com Guest
Posted: Tue Mar 06, 2007 8:00 am Post subject: RV8-List Fuel Tank Clamps |
Dear Thread Friend & Builders, I'm about to install the rear baffle in my RV-8a wing tank. The instructions mention using 'C' clamps and large spring clamps to assist in squeezing the ProSel out and getting a better fit. I can't picture where these clamps should go. Nose skin tip to baffle ? Side to side ? Anybody got an idea ? I could use the advise to picture how these go, Thanks, Bill
| | - The Matronics RV8-List Email Forum - | | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
heath.cherneski(at)gmail. Guest
Posted: Tue Mar 06, 2007 11:49 am Post subject: RV8-List Fuel Tank Clamps |
Hey Bill,
When installing the rear baffle on my tanks I cleco’d every rivet hole to make sure I got a good fit and then removed every other cleco to begin riveting. I squeezed these rivets since they were easy to access. I inspected my fit after cleco to ensure I did not have any “bubbles” between the skin and the baffle. I think the intent of the c-clamps was to ensure your fit was smooth and flat (ie no “bubbles” or “bumps”). Also, if you can ensure your pro-seal application is even along this seem, then you will have a better fit as well. My buddy and I have completed four tanks (rv8 and rv7) with no leaks. I erred on the side of no leaks when applying pro-seal in this seam and so went a little heavy. However, I have no leaks. Anyway, good luck. Hope this helps. My least favorite work so far has been with pro-seal, followed closely by fiberglass work.
Heath Cherneski (RV8 82519) (no N number yet)
Enterprise, Al
From: owner-rv8-list-server(at)matronics.com [mailto:owner-rv8-list-server(at)matronics.com] On Behalf Of japhillipsga(at)aol.com
Sent: Tuesday, March 06, 2007 9:59 AM
To: rv8-list(at)matronics.com
Subject: Re: RV8-List Fuel Tank Clamps
