fvalarm(at)rapidnet.net Guest
Posted: Wed Mar 07, 2007 7:10 pm Post subject: GPS antenna. |
I assume a remote GPS antenna will work fine on my RV7 located on top of the glare shield but under the windshield. Is anybody operating with this configuration successfully (Garmin 296 or 396)? If so, which antenna are you using.
Bevan
bobbyhester(at)charter.ne Guest
Posted: Wed Mar 07, 2007 7:36 pm Post subject: GPS antenna. |
I use the antenna that came with my Garmin 296 car kit in the plane and I use the extra one I bought off ebay when I travel in rental car. The Garmin one in the plane is mounted on my glare sheild with velcro
Goto this page http://webpages.charter.net/bobbyhester/MyFlyingRV7A.htm and scroll to the bottom, them click the picture to enlarge.
I think the one off ebay with the magnet would work just fine here also. It might mess with the compass, not sure.
B Tomm wrote: [quote] I assume a remote GPS antenna will work fine on my RV7 located on top of the glare shield but under the windshield. Is anybody operating with this configuration successfully (Garmin 296 or 396)? If so, which antenna are you using.
Bevan
| [b]
kahuna
Posted: Thu Mar 08, 2007 3:50 am Post subject: GPS antenna. |
Yes this will work fine.
I have 5 little hockey puck antennae’s on my glare shield. (3GPS and 2 XM)
2 panel GPS’s, and one 295 that my wife gets in the rear. One XM wx on the grt and one XM for radio.
Photo on the Mirrors link on this page.
http://www2.mstewart.net:8080/super8/index.htm
It makes for short wire runs, light weight, and ease of service IF you have access panels.
If you have more than one GPS antennae, they need to be several inches apart or you will get signal degradation between them, although they will work.
Mike
From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of B Tomm
Sent: Wednesday, March 07, 2007 10:07 PM
Subject: GPS antenna.
Bevan
| Quote: | | http://www.matronics.com/Navigator?AeroElectric-List | 01234
Dale Ensing
Posted: Thu Mar 08, 2007 5:32 am Post subject: GPS antenna. |
I have the 296 with the Garmin remote antenna mounted with Velcro on the glare shield and it works well. However, I discovered the placement of the antenna in relationship to the GPS unit is a factor.
My 296 is mounted externally on the panel at the top of the radio stack and just below the glare shield over hang. When the remote antenna is place on the aft edge of the glare shield right above the GPS it well not work. Moved to the far forward part of the glare shield, next to the windshield, it works fine. I confirmed this outside the airplane. With the GPS in my hand and receiving signal using the stub antenna, I switched to the remote antenna and held it in the same position as the stub antenna. The GPS soon stop working. When I held the remote antenna at arms length it resumed working.
My original setup was a 295 mounted in the same location with the remote antenna mounted just above it and it worked. Can anybody explain this to me? Could the magnet in the 296 remote be the cause?
Dale Ensing
_________________ Dale Ensing
RV-6A
Aero Plantation
Weddington NC |
jrichard(at)ccser.com Guest
Posted: Thu Mar 08, 2007 7:17 am Post subject: GPS antenna. |
Mike. I looked at the link showing your panel. Very nice.
Quick question: I see your initial design was using the Garmin 480 GPS navigator, then you changed to the 430 GPS. Do you think Garmin will obsolete the 480 soon?
John
From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Stewart, Michael (ISS Atlanta)
Sent: Thursday, March 08, 2007 3:39 AM
Subject: RE: AeroElectric-List: GPS antenna.
Mike
Bevan
| Quote: | | http://forums.matronics.com |
kahuna
Posted: Thu Mar 08, 2007 8:21 am Post subject: GPS antenna. |
Where did you see the 480 as initial design?
I never considered it in my panel and I I can only comment on my personal opinion as to the 480. I think it will die. It is based on nothing but guess work looking at their portfolio and product roadmap.
Since I have the MX20, there is no need for the 480 IMHO.
Best,
Mike
From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of John Richardson
Sent: Thursday, March 08, 2007 10:16 AM
John
Subject: RE: GPS antenna.
Mike
Bevan
| Quote: | | http://forums.matronics.com | 012345678
Posted: Thu Mar 08, 2007 8:42 am Post subject: GPS antenna. |
I saw the 480 in the top picture at this link
http://www2.mstewart.net:8080/super8/panel/index.htm
I think your conclusion about Garmin’s roadmap is correct. I happen to like the 480 and would like to see it stick around. Oh well.
John
Sent: Thursday, March 08, 2007 8:13 AM
Best,
Mike
John
Mike
Bevan
| Quote: | | http://forums.matronics.com | 0123456789 | Quote: | | http://www.matronics.com/Navigator?AeroElectric-List | 0 | Quote: | | http://www.matronics.com/Navigator?AeroElectric-List | 1 | Quote: | | http://www.matronics.com/Navigator?AeroElectric-List | 2 | Quote: | | http://www.matronics.com/Navigator?AeroElectric-List | 3
kahuna
Posted: Thu Mar 08, 2007 10:35 am Post subject: GPS antenna. |
No 480 there.
A GRT center top in the panel.MX20 center bottom, ACS engine monitor bottom right.
430 on the top left.
Mike
Sent: Thursday, March 08, 2007 11:42 AM
John
Best,
Mike
John
Mike
Bevan
| Quote: | | http://forums.matronics.com | 0123456789 | Quote: | | http://www.matronics.com/Navigator?AeroElectric-List | 0 | Quote: | | http://www.matronics.com/Navigator?AeroElectric-List | 1 | Quote: | | http://www.matronics.com/Navigator?AeroElectric-List | 2 | Quote: | | http://www.matronics.com/Navigator?AeroElectric-List | 3 | Quote: | | http://www.matronics.com/Navigator?AeroElectric-List | 4 | Quote: | | http://www.matronics.com/Navigator?AeroElectric-List | 5 | Quote: | | http://www.matronics.com/Navigator?AeroElectric-List | 6 | Quote: | | http://www.matronics.com/Navigator?AeroElectric-List | 7 | Quote: | | http://www.matronics.com/Navigator?AeroElectric-List | 8
Bill Denton
Joined: 10 Jan 2006 Posts: 97 Location: Chicago, IL USA
Posted: Thu Mar 08, 2007 10:59 am Post subject: GPS antenna. |
Mike...
In the "planning" picture at the top of the page there is a 480 between the airspeed indicator and the transponder.
Bret Smith
Joined: 09 Jan 2006 Posts: 178 Location: Mineral Bluff, GA
Posted: Thu Mar 08, 2007 11:46 am Post subject: GPS antenna. |
Mike, John is correct, it IS a 480 on your proposed panel. You must have accidentally drug up the 480 thinking it was a 430.
Bret
_________________ Bret Smith
RV-9A (Emp) |
kahuna
Posted: Fri Mar 09, 2007 4:45 am Post subject: GPS antenna. |
Well Ill be darned.
Sure nuff was.
OK I fixed it.
You guys have good eyes. Ive looked at that a hundred times and never caught it.
Sorry for the confusion.
Mike
From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Bill Denton
Sent: Thursday, March 08, 2007 1:59 PM
Mike...
-----Original Message-----
From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com]On Behalf Of Stewart, Michael (ISS Atlanta)
Sent: Thursday, March 8, 2007 12:33 PM
No 480 there.
Mike
John
Best,
Mike
John
Mike
Bevan
| Quote: | | http://forums.matronics.com | 0123456789 | Quote: | | http://www.matronics.com/Navigator?AeroElectric-List | 0 | Quote: | | http://www.matronics.com/Navigator?AeroElectric-List | 1 | Quote: | | http://www.matronics.com/Navigator?AeroElectric-List | 2 | Quote: | | http://www.matronics.com/Navigator?AeroElectric-List | 3 | Quote: | | http://www.matronics.com/Navigator?AeroElectric-List | 4 | Quote: | | http://www.matronics.com/Navigator?AeroElectric-List | 5 | Quote: | | http://www.matronics.com/Navigator?AeroElectric-List | 6 | Quote: | | http://www.matronics.com/Navigator?AeroElectric-List | 7 | Quote: | | http://www.matronics.com/Navigator?AeroElectric-List | 8 | Quote: | | http://www.matronics.com/Navigator?AeroElectric-List | 901234567
