RotaxEngines-List Digest: 1 Msgs - 03/04/07
service(at)b-bar-daviatio
PostPosted: Mon Mar 05, 2007 7:04 am    Post subject: RotaxEngines-List Digest: 1 Msgs - 03/04/07 Reply with quote
Hugh:
Looking at Fig. 29 on page 46 of the installation manual... in the
bottom right corner just to the right of the 30A fuse the diagram says
"Batterie+..." That should be wired into the master switch (not directly
to the battery), then to the battery on the other side of the switch.
The regulator does allow a slow drain of the battery if you wire it
exactly as Rotax describes in this installation manual. I don't remember
the exact numbers, but I do remember the headaches.
Best regards,
Matt Smith
9:41 AM
