nuckollsr(at)cox.net Guest
Posted: Sun Mar 04, 2007 8:37 pm Post subject: Radio interference to instruments |
| Quote: | Comments/Questions: When I push my PTT switch to transmit on my radio I
get an increase in manifold pressure and either a large increase or
decrease in ammeter reading. This is intermittent and happens about 80%
of the time. All works great with the radio off.
Sounds like these instruments were not designed to live
in the real world of airplanes. They seem to suffer from
radio frequency interference.
Check your coax cables from transceiver to antenna. If the
shield ground comes loose at either end, the coax can radiate
very strongly into airframe wiring.
You might try putting a ferrite cable-choke-core over the
bundles going into the back of these instruments. See:
http://tinyurl.com/28bdgm
( IF one wishes to be "world class" at )
( anything, what ever you do must be )
( exercised EVERY day . . . )
( R. L. Nuckolls III )
Randy.McFarland(at)novell Guest
Posted: Mon Mar 05, 2007 8:26 am Post subject: Radio interference to instruments |
Thx for the question.
I have the same problem. I have a SD8 and Denso 60amp being monitored by a
EIS 4000 engine monitor. The alarm goes off almost every time I key the Mic
PTT due to one or both Amp readings going out of limits (typically decrease)
Doesn't seem to matter whether I am transmiting using Garmin 430 or KX125.
I'll check my coax cabling and shields.
Randy
Bill Denton
Joined: 10 Jan 2006 Posts: 97 Location: Chicago, IL USA
Posted: Mon Mar 05, 2007 9:07 am Post subject: Radio interference to instruments |
May or may not be relevant...
Keep in mind that your power consumption goes up quite a bit when you key
the mic. Your transponder also has pulsed of higher power consumption.
I've heard of guys who set their alarms based on the airplane running with
everything turned on. But when they key their mic, especially when the
transponder is also transmitting, they get an alarm.
As I said, maybe not relevant to your situation, but you might consider
it...
N6030X(at)DaveMorris.com Guest
Posted: Mon Mar 05, 2007 10:10 am Post subject: Radio interference to instruments |
Whenever I hear of RF producing a DC voltage effect somewhere, I
immediately think "corrosion". Dissimilar metals, moisture,
corrosion, rectification. I've seen bad splices wipe out an entire
manufacturing plant's data network, but only when it rains. Check
your connectors for white powder and the back of your panel for moisture.
Dave Morris
it...
