Wing Heights
jim(at)CombsFive.Com
PostPosted: Sun Mar 04, 2007 6:01 am    Post subject: Wing Heights Reply with quote
I have a hanger that can be shared with an RV-7. Can someone with a finished aircraft give the a couple of distance measurements?
(1) Just outside the main landing gear, Distance to the bottom of the wing to the ground. Spar and edge of raised flap.
(2) At the wing tip / wing intersection, Distance to the bottom of the wing to the ground. Spar and rear edge of wingtip
(3) Tail tie down to ground measurement.
We are looking to see if the wings will overlap enough to allow really close quarters. It would be nice not to have to move one airplane to get the other out.
Thanks, Jim Combs
N312F - Finish Kit
40192
wvu(at)ameritel.net
PostPosted: Sun Mar 04, 2007 6:26 am    Post subject: Wing Heights Reply with quote
Jim, I'm about to go to the airport for some hangar flying (gusting to 40
today). I'll try to do that for you. Meanwhile attached are two pictures
which you can use a ruler and estimate if it'll work for you. Perhaps an
Aerolift like the one shown in the pictures is one solution. If you do take
this route, just know that it does not work quite well with RV-10s yet. I'm
working with them to resolve this.
Anh
N591VU
 Filesize:  85.88 KB
 Viewed:  230 Time(s)
 Filesize:  89.68 KB
 Viewed:  230 Time(s)
PostPosted: Sun Mar 04, 2007 6:46 am    Post subject: Wing Heights Reply with quote
Anh, Thanks,
Date: 2007/03/04 Sun AM 09:23:59 EST
Subject: Re: Wing Heights
Jim, I'm about to go to the airport for some hangar flying (gusting to 40 today). I'll try to do that for you.
Anh
N591VU
