wslaughter(at)houston.rr. Guest
Posted: Fri Mar 02, 2007 6:28 pm Post subject: Battery Tenders |
Bob,
Speaking of Battery Tenders... I sent my Battery Tender Plus off to you via
UPS on 2/22/07. Please let me know if you've received it or if I need to
start tracking.
William Slaughter
nuckollsr(at)cox.net Guest
Posted: Fri Mar 02, 2007 8:04 pm Post subject: Battery Tenders |
At 08:27 PM 3/2/2007 -0600, you wrote:
<wslaughter(at)houston.rr.com>
Bob,
start tracking.
I received it, did a test with it and put it back into
the mail today. I published a plot on a Battery Minder
some months ago at:
http://www.aeroelectric.com/Pictures/Curves/Battery_Minder_Recharge.pdf
Your Battery Tender did this recharge profile.
http://www.aeroelectric.com/Pictures/Curves/Battery_Tender_Recharge.pdf
We can deduce that both of these products service the "top off"
protocols and then drop to similar sustaining voltages.
Thank you for donating the use of your charger for this experiment.
( IF one aspires to be "world class", )
( what ever you do must be exercised )
( EVERY day . . . )
( R. L. Nuckolls III )
Posted: Mon Mar 05, 2007 5:57 pm Post subject: Battery Tenders |
The Battery Tender Plus arrived back home today - thanks. If I'm reading the
graphs right, it did perform rather differently than the previously tested
"Batter Minder" (actually a Deltran Battery Tender Jr., wasn't it?) While
the "Battery Minder" climbed to not-quite 14.0 and then dropped to float
mode, the BT+ appears to have climbed smoothly to 14.2 volts, and then held
between 14.2 and 14.4 for a dwell time of over an hour (if the time axis is
the same as the earlier test), before dropping back to 13.2 float. This
profile is just as advertised on the Deltran website. It's nice when things
perform as advertised. Thanks for running these tests.
William
