Bill Vincent
Posted: Tue Mar 06, 2007 5:57 pm Post subject: Spring clips on float bowls |
Hi Gang
Although I have never had any trouble with my Spring Clip loosing up on my Float Bowls (dual carb 503), I am wondering if I should be safety wiring the spring clips?
Has anyone ever had one loosen up in flight?
Bill Vincent
FS II
Upper Peninsula of Michigan
_________________ Bill Vincent
Firestar II
Upper Peninsula of Michigan |
Richard Pike
Posted: Tue Mar 06, 2007 6:05 pm Post subject: Spring clips on float bowls |
I have never heard of one doing it.
But they are not fool proof. (Never under estimate a fool...)
Richard Pike
MKIII N420P (420ldPoops)
Kolb MKIII N420P (420ldPoops)
Kingsport, TN 3TN0
olendorf
Joined: 06 Jul 2006 Posts: 140 Location: Schenectady, NY USA
Posted: Tue Mar 06, 2007 6:51 pm Post subject: Re: Spring clips on float bowls |
I have a spring on my clip that goes around the protusion at the bottom of the bowl. That gives me a little extra protection from the clip coming loose and doesn't interfere with removing the float bowl. Although I have never seen a clip come loose either. I do it because the spring was there when I bought the plane. I can't see any reason to remove it now.
_________________ Scott Olendorf
Original Firestar, Rotax 447, Powerfin prop
Schenectady, NY
http://sites.google.com/site/kolbfirestar/ |
