tleiss(at)earthlink.net Guest
Posted: Thu Mar 01, 2007 4:39 pm Post subject: 912 Carbs |
Looking for some help.
My Rotax 912UL is running very rough at Idle. Also have fuel running out the vent tubes unless idle is above 2400rpm. I have rebuilt both carbs (Bing 64) with kits from Bing. Initial set-up as described in the Bing instructions. I have synchronize the carbs with duel vacuum gauges. However, adjusting the mixture screws has virtually no effect in RPM or the vacuum gauge readings. Ignition is working fine, all new plugs. All new connectors and good drop-offs when switching A or B (Mag Check).
I have compared my engines performance with two other 912 equipped planes on the field. Mine is much rougher at low and medium speeds.
One question is if the Carb piston vents go towards the intake manifold (as I have them) or the intake.
Engine has 200 hours (192 by previous owner), 1 hour flight time since I've owned it and the rest are ground runs trying to get it running right.
Todd Leiss
Kitfox IV Speedster
N926JB
Merritt Island Florida
flier(at)sbcglobal.net Guest
Posted: Thu Mar 01, 2007 6:53 pm Post subject: 912 Carbs |
Todd,
Fuel is running out the vent tubes due to the shaking of the carbs. The idle mixture needs to be established before syncing. Be sure the engine is at temp before trying to do any tuning.
Do you have the Bing manual? I rebuilt mine late last year and it took some time to get them back into sync and running smoothly. Give Bing a call. Those guys are very helpful.
Ted
From: owner-kitfox-list-server(at)matronics.com [mailto:owner-kitfox-list-server(at)matronics.com] On Behalf Of Todd Leiss
Sent: Thursday, March 01, 2007 6:38 PM
To: kitfox-list(at)matronics.com; rotax-list(at)matronics.com
Subject: 912 Carbs
Todd Leiss
Kitfox IV Speedster
N926JB
href="http://www.matronics.com/Navigator?Kitfox-List">http://www.matronhref="http://forums.matronics.com">http://forums.matronics.com
lcfitt(at)sbcglobal.net Guest
Posted: Thu Mar 01, 2007 7:31 pm Post subject: 912 Carbs |
Hi Todd,
I had the exact same problem after a rebuild with the Bing kit. I traced it
to the carb float needles. Apparently they offer three types. I don't
recall which ones are which, although they can be identified by color. The
912ULS has a black one, Mine are yellow metal, as I recall and the other
ones are white metal.
I finally had to go back to the old ones per the Rotax inspection
procedures. Smothed right out and no more fuel dripping. The inspection
procedure is issentially to look at the spring loaded pin end and if you see
no wear under the crimp where the pin flange would be. They are good to go.
I called Bing and learned this stuff, but got no satisfaction. That is why
the change back to the old needles.
Regarding the guages. It is my understanding that you set the cable lengths
to balance the carbs. The start point of the idle jets is 1.5 turns from
full closed. After the cables are adjused to balance the vacuum gauges, the
jet can be tweeked to improve idle. What you are doing in this procedure is
making sure the throttle butterflys are opening at the same time, hence the
vacuum gauges.
Lowell
Posted: Thu Mar 01, 2007 9:30 pm Post subject: 912 Carbs |
Some more info on my carb problem:
My vent tubes are the proscribed length (about 4 inches), and tucked under
the float bowl spring clip.
I have new Boots or Flanges.
Vents under Carb inlets are free. Carbs are facing the correct way.
Synchronized by the Lockwood method (two Vacuum gauges) adjusting the
throttle cables as described in a "power-up" article.
On the bottom of the Carb slide (with long needle valve set at proscribed
clip position) there are two vent holes. Do these face the air filter or
Intake manifold (as I have them)?
I have a new (Jan 07) Fuel pump from Lockwood. I had ignition issues,
which I solved, but around the same time my old fuel pump started to leak.
The carbs didn't have the fuel running out the vents before the new pump,
but it never occurred to me that the pump could be the problem. This may
very well be the issue. I will definitely check with Lockwood tomorrow
concerning the fuel pressure.
Keep the wonderfully helpful cards and letters coming.
All the Best,
Todd
| Quote: | [Original Message]
To: <rotaxengines-list(at)matronics.com>
Date: 3/1/2007 10:15:21 PM
Subject: RotaxEngines-List: Re: 912 Carbs
Hi Todd,
Question: Are both carbs actting up in the same way?
Those vents you describe on the carb throat edges are actually inlets.
They must face out towards the air cleaner side or you will have the
problems as you describe. These intakes help work the diaphram in the top
of your carb for pressure changes.
If this was the problem your home free, if not:
One of the things you need to check is your fuel pump pressure. There is
a new service bulletin out on certain serial numbered engines that they
want these pumps replaced. The symptoms are as you describe. The max
pressure (without the manual in front of me) is 5.6 psi and some of these
pumps are putting out in the 9psi range.
| Quote: | This type of pressure will cause what you have described. There is a
replacement program as I understand it.
| Quote: | Your mixture screw should be set at 1.5 turns and left alone. Then you
should set the carb's idel screw with the engine off and then while it is
running.
Float Flyr
Posted: Fri Mar 02, 2007 5:43 am Post subject: 912 Carbs |
The two stroke Bing carbs now have a tube which connects the left bowl vent
with the right bowl vent and then a couple of small holes pierced through
the tubing near the bottom of the loop. This was done to keep air from
blowing gas out of the bowls. It's just an Idea but it may just work for
you too.
Noel
[quote] --
_________________ Noel Loveys
Kitfox III-A
Aerocet 1100 Floats |
kitfoxmike
Posted: Fri Mar 02, 2007 7:03 am Post subject: Re: 912 Carbs |
The float needles that I used were the 261-705 from ACS there are about 15 ea. I removed my spring clips on both sides, I felt they were keeping things from working right, lockwood said those are only there for install ease. If you find any particals in the fuel in the bowls, two things to do. replace all hoses with auto fuel injection hose, next put small rock filters just before the carbs. These needles have a black tip, rubber. Lockwood said that the black is the best, has the strongest spring inside.
On adjusting the carbs, I've never had good luck with the vacuum deal. What I do is open the throttle all the way and then check at the carbs to make sure the levers are the same against the stop, I have mine set up to be about 1/32 to 1/64 end gap on both sides. This should get you real close, and then put the idle stop the same on both sides, loosen up the stop and bring it to the arm and go the same amount of turns to set the idle.
Posted: Fri Mar 02, 2007 7:56 am Post subject: 912 Carbs |
The fuel running out your vents is due to shaking of the carbs (most likely)
or the floats set too high.
kitfoxmike
Posted: Fri Mar 02, 2007 9:39 am Post subject: Re: 912 Carbs |
Or the float needle stuck open, been there.
pulsair(at)mindspring.com Guest
Posted: Fri Mar 02, 2007 11:24 am Post subject: 912 Carbs |
Or the choke is stuck.
barry(at)pgtc.com Guest
Posted: Fri Mar 02, 2007 2:22 pm Post subject: 912 Carbs |
Some shaking, vibration, can cause the gasoline to foam which causes it to
come out of the overflow tube.
Barry West
