Switch drilling template
Gilles.Thesee(at)ac-greno
PostPosted: Thu Mar 01, 2007 1:59 pm    Post subject: Switch drilling template Reply with quote
Hi all,
Anyone can direct me to a drilling drawing or template I could print for
a buddy to install his Otto T7 15/32 switches ?
I remember seeing such a drawing, but can't remember where.
Thanks in advance,
Gilles
http://contrails.free.fr
steerr(at)bellsouth.net
PostPosted: Thu Mar 01, 2007 4:45 pm    Post subject: Switch drilling template Reply with quote
There's one on page 11-16 of Bob's book. It's Figure 11-12. That's
assuming the switches you mention are the same as the Carling switches
described in the book. The 15/32 diameter is the same.
Bill
Anyone can direct me to a drilling drawing or template I could print for a
nuckollsr(at)cox.net
PostPosted: Fri Mar 02, 2007 1:12 pm    Post subject: Switch drilling template Reply with quote
Bill
There's also a suggested set of layouts at:
http://www.aeroelectric.com/PPS/Mechanical/Switches.pdf
The standard toggles mount nicely on 0.8" centers. I'm
going to be adding a drill fixture to the products on
the website in about a week that will assist in drilling
precision spaced and properly aligned holes at 0.7, 0.8 and
0.9 inch intervals.
( IF one aspires to be "world class", )
( what ever you do must be exercised )
( EVERY day . . . )
( R. L. Nuckolls III )
PostPosted: Fri Mar 02, 2007 2:50 pm    Post subject: Switch drilling template Reply with quote
Robert L. Nuckolls, III a écrit :
<nuckollsr(at)cox.net>
> <steerr(at)bellsouth.net>
> switches described in the book. The 15/32 diameter is the same.
Bill and Bob,
Thank you. I knew it was there, but memory is failing.
Best regards,
Gilles
