Larger fuse link
steerr(at)bellsouth.net
PostPosted: Mon Feb 26, 2007 2:58 pm    Post subject: Larger fuse link Reply with quote
Hi, Bob. I need to put a fuse link in a 14 AWG wire - the endurance buss
feed in Z-1. The fuselink article on your site says to contact you if fuse
links larger than 22 AWG are needed. Is there an article for the larger
fuse link?
Thanks very much for your help.
Bill
nuckollsr(at)cox.net
PostPosted: Wed Feb 28, 2007 10:44 am    Post subject: Larger fuse link Reply with quote
fuse links larger than 22 AWG are needed. Is there an article for the
larger fuse link?
No . . . larger fuse links are not recommended except
in those few places where they're illustrated in the Z-figurs.
An e-bus feeder of that size should come through a relay
(mini-contactor) tapped off a fused slot on the battery
bus a illustrated in:
http://www.aeroelectric.com/Pictures/Schematics/E-BusFatFeed.gif
( IF one aspires to be "world class", )
( what ever you do must be exercised )
( EVERY day . . . )
( R. L. Nuckolls III )
