Registration related
demeo(at)sonic.net
PostPosted: Sun Feb 25, 2007 8:09 pm    Post subject: Registration related Reply with quote
I am filling out the forms for registration of my 601xl. I want to
register as E-LSA. Everything is fairly simple until I get to form
8130-6 which is the "Application for U.S. Airworthiness Certificate".
Under "certification requested" I check "B" - Special Airworthiness
Certificate", and "4" - Experimental". Now, under "4" do I also check
"2" Amateur Built" and/or "8" - "Operating Light Sport"? and "8c" -
"Operating light-sport previously issued special light-sport category
airworthiness certificate under 21.190"?
Any help is greatly appreciated.
Brad DeMeo
Working on Canopy
demeo.vcf
 Filename:  demeo.vcf
 Filesize:  264 Bytes
 Downloaded:  196 Time(s)
bryanmmartin
PostPosted: Mon Feb 26, 2007 4:37 am    Post subject: Registration related Reply with quote
2 is for registering the airpland as E-AB. 8c is for transitioning a currently registered S-LSA to E-LSA status. So you want to go with 8- Operating Light Sport if this is a newly constructed airframe that has never been regisered before. You can only check one of the three.
The only difference between E-LSA and E-AB is who can sign off the annual inspections. For E-AB you as the builder can apply for the repairman certificate for that airplane and sign off you own annuals but anybody you sell it to can't - they'll have to get an A&P to do that. For E-LSA, you'll have to take a 16 hour repairman course to get the certificate that allows you to sign off the annual and anybody you sell the plane to can do the same. Either option will allow the plane to be operated under the sport pilot rules.
On Feb 25, 2007, at 11:08 PM, Brad DeMeo wrote:
I am filling out the  forms for registration of my 601xl.  I want to register as E-LSA.  Everything is fairly simple until I get to form 8130-6 which is the "Application for U.S. Airworthiness Certificate".  Under "certification requested" I check "B" - Special Airworthiness Certificate", and "4" - Experimental".  Now, under "4" do I also check "2" Amateur Built" and/or "8" - "Operating Light Sport"? and "8c" - "Operating light-sport previously issued special light-sport category airworthiness certificate under 21.190"?
Bryan Martin
N61BM, CH 601 XL,
RAM Subaru, Stratus redrive.
do not archive.
Bryan Martin
do not archive.
amyvega2005(at)earthlink.
PostPosted: Mon Feb 26, 2007 5:47 pm    Post subject: Registration related Reply with quote
you check 2 amateur built.
Juan
PostPosted: Mon Feb 26, 2007 5:48 pm    Post subject: Registration related Reply with quote
actually the best thing to do is to call the FAA, they were a great assistance in helping me fill out the paper work. you call, there is a little waite, they come on line and you can ask them to walk you through the whole document.
Juan
