Evans Coolant and Rotax Airbox
beachyjeff(at)juno.com
PostPosted: Thu Feb 22, 2007 12:57 pm    Post subject: Evans Coolant and Rotax Airbox Reply with quote
I am planning on running Evans coolant in my new 912ULS. I noticed that
some slight residue was in the coolant system, presumably from a factory
test run. Is it necessary to flush a brand new engine before using Evans,
or is it okay to simply use Evans from the first fill?
Also, on my Rotax airbox, I have the small bottom end holes attached to
hoses which I have run down to the slipstream. Is this correct? I know
not to extend the carb lines down due to the pressure compensating
feature, but is this a non-factor when using the Rotax airbox?
Thanks!
Jeff Beachy
Zenith CH701
Roger Lee
PostPosted: Thu Feb 22, 2007 5:32 pm    Post subject: Re: Evans Coolant and Rotax Airbox Reply with quote
Hi Jeff,
If all the water is out except for a few spoon fulls which you coudn't get out anyway the just go with the Evans. I have used Evans in my last plane and my new one and I have been happy.
I'm not sure about the airbox. Look online under Rotax/Kodiak and look under their installation manual.
Roger Lee
Tucson, Az.
Rotax Instructor & Rotax IRC
Light Sport Repairman
Cell 520-349-7056
