CJohnston(at)popsound.com Guest
Posted: Wed Feb 21, 2007 6:36 pm Post subject: 28v switches in a 12v system? |
Alright smart guys... here's my dumb question of the day...
Can I use LED illuminated switches designed for a 28 volt system in a 12
volt system? Why or why not? What would theoretically happen? I
imagine that I'm fully displaying my lack of understanding in this area,
but try to be gentle.
Thanks!
cj
nuckollsr(at)cox.net Guest
Posted: Wed Feb 21, 2007 7:23 pm Post subject: 28v switches in a 12v system? |
At 06:32 PM 2/21/2007 -0800, you wrote:
Quote: |
<CJohnston(at)popsound.com>
Sure, they'll just be dim compared to the 14v illumination
level. Better get one, hook it to a battery and see if
the illumination level is still satisfactory to your needs.
( IF one aspires to be "world class", )
( what ever you do must be exercised )
( EVERY day . . . )
( R. L. Nuckolls III )
mprather(at)spro.net Guest
Posted: Wed Feb 21, 2007 8:05 pm Post subject: 28v switches in a 12v system? |
It won't hurt anything, but they'll be dimmmer. LED's like most diodes
have very non-linear current vs. voltage curves. Below the knee voltage
the current is nearly zero. Once the voltage goes above gets above the
knee, the current increases rapidly for small increases in voltage. A
typicl LED knee voltage is about 1.5V. Changing from 28V to 12V will
still keep the voltage applied to the LED above the knee voltage.
For the purposes of your question, let's assume that for both 12V and 28V
the voltage across the LED is 1.7V - a safe assumption, though not
perfectly accurate.
Let's also assume that the current through the LED at 28V was 20mA. That
says the switch has a dropping resistor with a value given by R = V/I =
(28V - 1.7V) /20mA = 1315ohm.
Next, let's calculate the current through the circuit when running with a
12V supply. I = V/R = (12V - 1.8V) / 1315ohm = 7mA
When considering light output, the key is about power. Let's compare.
P(28V) = 20mA * 1.7V = 34mW
P(12V) = 7mA * 1.7V = 12mW
So, I would expect that when running the 28V switches at 12V, the emitted
light would be about one third. Maybe less, actually. At the lower
current, the voltage drop across the diode is going to be a little less,
so the power is going to be a little less too. At 1.5V the power is
10.5mW.
Hope that helps..
Matt-
Thanks!
cj
