		f1rocket(at)telus.net Guest
				 Posted: Sat Feb 17, 2007 7:42 pm    Post subject: Exhaust BPA interference |
				Hi all,
 Today I finally got around to installing my cold air induction and inverted
 system.  Of course I left the exhaust to last.  I have been running a
 Vettermann system, love it and people tell me it sounds great on the ground.
 Problem is that it interferes with the BPA cold air induction piping.
 Does anyone out there have the BPA system?  If so what exhaust are you
 running and where can I get my hands on one?
 Jeff
  |  | - The Matronics Rocket-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
		Deems Davis
				 Posted: Sat Feb 17, 2007 8:15 pm    Post subject: Exhaust BPA interference |
				John Forsling makes tuned exhaust for BPE Cold air. He is recommended by
 Allen Barrett. John actually spent time in BPE's shop and built several
 exhausts and ran them on BPE's dyno to see what worked and what didn't.
 John used to work work Vetterman before going off on his own. He's not
 an e-mail/computer guy. e-mail me off line for his phone number. I have
 his exhaust but have not installed it yet. It's ceramic coated inside
 and out and priced competitively.
 Deems Davis # 406
 Finishing - ( A Misnomer ! )
 http://deemsrv10.com/
		AV8ORJWC
				 Posted: Sat Feb 17, 2007 9:13 pm    Post subject: Exhaust BPA interference |
				John Forsling (Parker, CO) has Tuned Exhaust which is often ceramic
 coated, specifically routed for the Barrett Cold Air System and the
 Lycoming IO-540.
 John Cox
		mneufeld(at)verizon.net Guest
				 Posted: Sun Feb 18, 2007 2:16 am    Post subject: Exhaust BPA interference |
				DOES A CERAMIC COAT ON BOTH INSIDE AND OUT MAKE THE PIPES HOTTER, AS IT MAY CONTAIN THE HEAT, AND THEREFORE PIPES CRACK OR FATIGUE SOONER?
 mARK nEUFELD
 Date: 2007/02/17 Sat PM 10:15:16 CST
 To: rocket-list(at)matronics.com
 Subject: Re: Exhaust BPA interference
 Deems Davis # 406
		Blairclan(at)bigpond.com Guest
				 Posted: Sun Feb 18, 2007 2:41 am    Post subject: Exhaust BPA interference |
				I understand that John Harmon's exhaust is designed to fit the BPA
 setup.  Hard to find a cheaper exhaust and you know that heaps of them
 are in service!
 Good Luck
 Tony
		Deems Davis
				 Posted: Sun Feb 18, 2007 7:14 am    Post subject: Exhaust BPA interference |
				I have no 1st hand experience, as mine are not installed, however I have
 heard from an EAA chapter member who had his coated after he had been
 flying that his EGT's rose 75-100 degrees.  I have heard anecdotal
 stories both ways. i.e. that is shortens the life and that it extends
 it..... ?
 Deems Davis # 406
 Mark Neufeld - HR-2 wrote:
  mARK nEUFELD
  Deems Davis # 406
		AV8ORJWC
				 Posted: Sun Feb 18, 2007 11:48 am    Post subject: Exhaust BPA interference |
				Ceramic coat lowers the transfer of heat rate through the walls over a
 longer duration of time.  Lower cowl temperatures, better fuel flow.
 In Lancair's running the TSIO-550 it has been said that the ceramic
 coating can flake off the inside and kills the turbo.  I have heard no
 first hand reports to confirm the perception. When only one side is
 coated, the uneven cooling increases cracking at the flanges and welds.
 That has been documented but not directly linked to the ceramic coatings
 - it could have been questionable welds.
 The benefits versus perceived risks need further research.  The lower
 cowl temperatures are a big plus.
 John Cox
