Jason
Posted: Mon Feb 19, 2007 1:41 pm Post subject: 601 XL w/ Corvair PowerPlant |
Was hoping some of you 601 XL builders using the Corvair powerplant wouldn't mind sharing some of your plane specifications? I have been reading gobs about the engine and the plane and it seems like a pretty good fit to me, but I keep having one nagging problem and since I don't actually have a plane or any real experience, I was hoping that some of you might share.
I was curious what the useful load of a Corvair powered 601XL was?
With a full tank, using the Lycoming O-235 as a comparable engine of approximatly the same weight (from the XL specifications page), I'm basically getting that the max take off weight is about 375lbs(useful load w/ full tank).
This is important to me because my father and I are not small people, we both are over 200lbs and even our most optimal and healthy weight would still have us both over 200lbs. Can anyone speak to this from actual real first hand knowledge?
Any feedback greatly appreciated.
Jason
PS: My calculations were based on 24 gallons of fuel on the XL weighing 145lbs. 520-145 = 375lbs avaliable for two passengers.
Posted: Mon Feb 19, 2007 2:28 pm Post subject: 601 XL w/ Corvair PowerPlant |
Hi Jason,
I can't give you the information you ask, but perhaps I can help a little.
If you find the corvair engine is too heavy for your use, I suggest
you consider using either a Rotax or Jabiru engine. I believe each
of these choices is considerably lighter than any cast iron block engine.
Good luck,
Paul
XL fuselage (Jabiru 3300 on order)
At 01:41 PM 2/19/2007, you wrote:
basically getting that the max take off weight is about 375lbs.
Jason
PS: My calculations were based on 24 gallons of fule on the XL
http://forums.matronics.com/viewtopic.php?p=96098#96098
Paul Mulwitz
32013 NE Dial Road
Camas, WA 98607
Posted: Mon Feb 19, 2007 2:49 pm Post subject: 601 XL w/ Corvair PowerPlant |
Here is a quote from William Wynne's web site about their Corvair-equipped
601xl (look about 3/4s of the way down the page):
"Like Gus, Derek is a very burly guy. Together, they weigh more than 500
pounds. But the 601's efficient airframe, and its 44" wide cabin flew both
of them in comfort with a good rate of climb. In extreme cases like this, we
do not operate the airplane with full fuel. But two FAA sized people could
fill up the 24 gallon tanks on the XL, still carry 86 pounds of baggage, and
be within gross weight. With the standard Corvair engine, this combination
performs very well."
http://www.flycorvair.com/601.html
-- Craig
John Bolding
Posted: Mon Feb 19, 2007 3:08 pm Post subject: 601 XL w/ Corvair PowerPlant |
After reading Paul's posting on cast iron Corvairs I got real scared and ran out to the hanger to put a magnet on the Corvair block I'm building up with alum cyls. WHEW !!! It had NOT changed into cast iron overnight, it was STILL aluminum. Glad all that work and money to build a lightweight, CHEAP, 100 hp engine had not been destroyed.
I put a cover over it thou so any of those cast iron gremlins roaming around wouldn't find it and convert it . I've learned some new stuff today!!
LOW&SLOW John
--> Zenith-List message posted by: Paul Mulwitz <p.mulwitz(at)worldnet.att.net (p.mulwitz(at)worldnet.att.net)>
Hi Jason,
Good luck,
Paul
[quote]--> Zenith-List message posted by: "Jason" <ingram20(at)sbcglobal.net (ingram20(at)sbcglobal.net)>
btucke73(at)yahoo.com Guest
Posted: Mon Feb 19, 2007 6:16 pm Post subject: 601 XL w/ Corvair PowerPlant |
John,
You freakin' kill me... And you beat me to the
punch...
VR/
Brandon
601 HDS / TD / Corvair
70 hours - a few of them with two 200+ lb fat asses on board.
Expecting? Get great news right away with email Auto-Check.
Try the Yahoo! Mail Beta.
ashontz
Posted: Tue Feb 20, 2007 7:17 am Post subject: Re: 601 XL w/ Corvair PowerPlant |
| Jason wrote: | Was hoping some of you 601 XL builders using the Corvair powerplant wouldn't mind sharing some of your plane specifications? I have been reading gobs about the engine and the plane and it seems like a pretty good fit to me, but I keep having one nagging problem and since I don't actually have a plane or any real experience, I was hoping that some of you might share.
Jason
PS: My calculations were based on 24 gallons of fuel on the XL weighing 145lbs. 520-145 = 375lbs avaliable for two passengers. |
I think you'll find the new gross weight of the XL can be up to 1320 and still be sport pilot. Don't quote me though. I've seen people report and loaded XL with a Corvair weighing in at 735lbs giving, 1320 - 735 = 585 useful load. 585 - 145 = 440 means two 220lb people. I'd guess the that 735 may even be a bit high too. Depends on how many radios and whatnot you have in the thing. You could always go with 3/4 filled tanks too. How often will you be flying with your Dad? You could always look into the CH640. I believe that can even be built from plans. Don't know how heavy an engine that takes but I'd guess and Chevy small block v-6 conversion would fit confortably on that puppy and easily give you 180hp without stressing the engine. There's some good auto engine conversion books out there that feature the chevy v-6. I wouldn't put one on an XL though. The Corvair seems ideal for the XL.
Personally, I don't trust the high revving engines. Seems like too much stress and heat, plus they sound whacky. They don't sound like a real plane at all. Check out Scott Laughlin's videos of his Corvair running. Sounds awesome. www.cookinwithgas.com. I also don't trust the reduction belt drives on the Rotaxes. Ever have a timig belt go in a car? Same deal, except you can't pull over. Belts are great concepts for motorcycle drives, not for planes. Just more complications and things to go wrong. The idea behind an airplane engine is to be light, low-stress, simple, and reliable. And they're more reliable when they're simple. I have an 21 year 140hp outboard on my boat. Always runs. Simple design. I see more people with newer more complex engines broken down than Ive had problems myself. Same with airplane engines.
Gig Giacona
Posted: Tue Feb 20, 2007 8:52 am Post subject: Re: 601 XL w/ Corvair PowerPlant |
Jason, I don't know where you are located but if east central Fla is not to far away go by William Wynne's place. I'll bet you could talk him into a flight.
601XL Under Construction
hillsgun(at)nwinfo.net Guest
Posted: Tue Feb 20, 2007 9:38 am Post subject: 601 XL w/ Corvair PowerPlant |
It won't change to cast iron on it's own, it has to be sprinkled with castonium flakes, unfortunately it has some adverse side effects such as changing into a V-8.
Dan
Jason
Posted: Wed Feb 21, 2007 5:41 am Post subject: Re: 601 XL w/ Corvair PowerPlant |
I should be so lucky as to be able to stroll on over to talk with WW about this and get a demo ride on his 601. *grins* I think he's a pretty busy guy right about now, so I'm not going to pester him when I don't even have an engine to tinker with(however, did order and recieve his conversion manual).
Thanks for all your thoughts, I'm not sure if the 1320 is a "hard" limit, I'm assuming that for us we should treat it as a hard cieling, but am glad to know that more than a few of the XL/Corvair planes have and do fly loaded with some healthy sized guys aboard without problem.
Jason
pmaxpmax(at)HOTMAIL.COM Guest
Posted: Wed Feb 21, 2007 12:17 pm Post subject: 601 XL w/ Corvair PowerPlant |
This is my experience also. I'm not a skinny guy and Gus and I flew all over Northern New Jersey for a couple of days. We flew with full tanks many times and went through all phases of flight. I'm not saying we we were over gross I set my gross weight to be in line with the Sport Pilot regulations. My plane will climb nicely slightly over gross.
My performance numbers are in the archives including weights etc.
Phil Maxson
601XL/Corvair
Northwest New Jersey
> From: craig(at)craigandjean.com
| Quote: | Subject: RE: 601 XL w/ Corvair PowerPlant
--> Zenith-List message posted by: "Craig Payne" <craig(at)craigandjean.com>
-- Craig
Explore the seven wonders of the world Learn more! [quote][b]
Gig Giacona
