| genaperevedent(at)yahoo.c Guest
				|  Posted: Thu Feb 02, 2006 3:08 pm    Post subject: Yak-55/55m gills |   |
				| Russian Maintenanse Schedule has a large section devoted to   seasonal  maintenanse. Preparations for spring/ summer operation  among other items require removal of gills. When gills are  removed,  don't forget to put fillets to the  front inner  parts of cawling covers.
Happy summer flying.
 Gena P.
 [quote]  *
 Today's complete Yak-List Digest can also be found in either of the
 two Web Links listed below.  The .html file includes the Digest formatted
 and Message Navigation.  The .txt file includes the plain ASCII version
 of the Yak-List Digest and can be viewed with a generic text   editor
 HTML Version:
 http://www.matronics.com/digest/yak-list/Digest.Yak-List.2006-01-31.html
 Text Version:
 http://www.matronics.com/digest/yak-list/Digest.Yak-List.2006-01-31.txt
 Yak-List Digest Archive
 Total Messages Posted Tue 01/31/06: 33
 Today's Message Index:
 1. 04:00 AM - Re: Re: Iris Instead of Grills  (Craig Payne)
 2. 05:07 AM - Re: gear problem  (cjpilot710(at)aol.com)
 3. 05:33 AM - Re: gear problem  (Fraser, Gus)
 4.  05:40 AM - Re: Iris Instead of Grills  (Fraser, Gus)
 5. 06:42 AM - Re: Going after overzealous FedsGoing after overzealous Feds  (Valkyre1)
 6. 06:51 AM - CJ6A: stations for CG calculation  (Brian Lloyd)
 7. 06:51 AM - Re: Useful VFR Maps Site  (Valkyre1)
 8. 06:59 AM - Re: Going after overzealous Feds  (Brian Lloyd)
 9. 07:14 AM - Re: Useful VFR Maps Site  (David McGirt)
 10. 07:14 AM - Re: Nuclear waste and Us vs. the Government (was:  Radium) [some of you will want to hit delete now] (Valkyre1)
 11. 07:22 AM - Re: Iris Instead of Grills  (marksorenson)
 12. 07:34 AM - Re: Hangars  (marksorenson)
 13. 07:37 AM - Re: Useful VFR Maps Site  (marksorenson)
 14. 09:14 AM - CJ  (doug sapp)
 15. 09:20 AM - Re: CJ6A: stations for CG calculation  (cjpilot710(at)aol.com)
 16. 09:40 AM - Re: CJ6A: stations for CG calculation  (Ernest Martinez)
 17. 09:54 AM - Re: CJ  (Scooter)
 18. 10:50 AM - Re: Iri  s  Instead of Grills  (Scott Kirk)
 19. 10:52 AM - Re: Re: Iris Instead of Grills  (Bitterlich GS11 Mark G)
 20. 10:56 AM - Re: Re: Re: Iris Instead of Grills  (Bitterlich GS11 Mark G)
 21. 10:57 AM - RedStar S. E. Region Pilots  (cjpilot710(at)aol.com)
 22. 11:00 AM - Re: Re: CJ  (doug sapp)
 23. 12:44 PM - Re: CJ6A: stations for CG calculation  (Brian Lloyd)
 24. 12:44 PM - Re: CJ6A: stations for CG calculation  (Brian Lloyd)
 25. 01:55 PM - Re: CJ  (cgalley)
 26. 03:50 PM - Overzealous Feds  (Frank Haertlein)
 27. 03:50 PM - Fun to fly again  (Frank Haertlein)
 28. 03:52 PM - Re: Nuclear waste and Us vs. the Government (was:  Radium) [some of you will want to hit delete now] (Frank Haertlein)
 29. 04:27 PM - Re: Overzealous Feds  (Brian Lloyd)
 30. 07:28 PM - Check your computers folks.  (fraseg)
 31. 07:53 PM - Re: 4 sale  (Michael Beach Hartwigs Trucks)
 32. 08:19 PM - gear retract   (jandefinley(at)comcast.net)
 33. 09:26 PM - Re: Going after overzealous Feds  (fish(at)aviation-tech.com)
 ________________________________  Message 1  _____________________________________
 Time: 04:00:46 AM PST US
 Subject: Re: RE: Iris Instead of Grills
 Mark G wrote:
  	  | Quote: |  	  | I ran them out from the front of the
 engine supercharger cover
 Hmmm, could that be the engine gearbox cover?
  	  | Quote: |  	  | (using the same mounting studs that the IRIS would attach to) HORIZONTALLY to the front cowl ring.  Four of them, one every 90
 degrees.  These acted like spokes on a wheel, and gave back the support that
 the original gills had.
 Result?  Problem cured.  No more cowling damage... problem is 100% FIX
 I too have removed the gills but left the gill outer ring in place with the original
 mounting rods. Since I have the C  rowder  spinner in place now, I'm watching
 it all very closely. Another problem I have noticed on cowls without gills
 is that the cowl skin UNDER the lower mounting brackets tend to crack through
 around the bracket that holds the "donuts" the pins go through. Doublers on the
 skin are required.
 Craig Payne
 ________________________________  Message 2  _____________________________________
 Time: 05:07:21 AM PST US
 Subject: Re: gear problem
 Terry,
 Walt makes some good  points.  But I would check your gear handle valve.  Me
 thinks, that  with the gear working AFTER you've put the handle in neutral
 (dumping all  pressure), that you may have a problem there in that the face of
 the valve may  be scratched or corroded allowing pressure to cross even if the
 valve moved to  the up side.
 Also might want to  recheck that emergency shuttle valve.  If you can sake it
 and hea  r the   valve spring back and forth, it's good.  If that valve is not
 seated just a  little bit, the gear will not re track.
 Jim "Pappy"  Goolsby
 ________________________________  Message 3  _____________________________________
 Time: 05:33:52 AM PST US
 Subject: RE: gear problem
 Emergency shuttle valve gets my vote, I had exactly the same issue and that
 was it.
 Gus
 _____
 [mailto:owner-yak-list-server(at)matronics.com] On Behalf Of cjpilot710(at)aol.com
 Sent: Tuesday, January 31, 2006 8:04 AM
 Terry,
 of the valve may be scratched or  corroded allowing pressure to cross even if
 the valve moved to the up side.
 and hear the valve spring back and forth, it's good.  If that valve is not
 Jim "Pappy" Goolsby
 bottomMargin=7 leftMargin=7 topMargin=7 rightMargin=7>
 gets my vote, I had exactly the same issue and that was it.
 Gus
 AM
 Subject: Re: gear
 problem
 style="BACKGROUND-COLOR: #80ff00">Terry,
 style="BACKGROUND-CO  LOR:  #80ff00">
 points. But I would check your gear handle valve. Me thinks, that
 with the gear working AFTER you've put the handle in neutral (dumping all
 pressure), that you may have a problem there in that the face of the valve may
 be scratched or corroded allowing pressure to cross even if the valve moved to
 the up side.
 Also might want to
 recheck that emergency shuttle valve. If you can sake it and hear the
 valve spring back and forth, it's good. If that valve is not seated just
 Jim "Pappy"
 Goolsby
 ________________________________  Message 4  _____________________________________
 Time: 05:40:24 AM PST US<  br>From:  "Fraser, Gus"
 Subject: RE: Iris Instead of Grills
 Un the Sukhoi and my SP the whole cowl is MUCH stronger than the standard
 50/52 cowl. For example, the front of the cowl is shaped like a wing there
 is baffling on the inside of the cowl that gives great strength. Also there
 are support arms from all cylinders to the cowl (see attached picture) I bet
 you have wondered what those bolts on the front of the cylinder were for,
 well guess no more because they are the mounting for the support arms.
 The diameter of the cowl opening is also slightly smaller hence the gap on a
 52 cowl when the flaps are closed.
 Hope this helps
 Gus
 _____
 [mailto:owner-yak-list-server(at)matronics.com] On Behalf Of Bitterlich GS11
 Mark G
 Sent: Monday, January 30, 2006 6:22 PM
 Hello Mark,
 [b]This  is ANOTHER "Mark" so this is bound to get confusing.  Tim mentioned my
 experience in regard to flying without gills, so I thought I would bring my
 experiences in this regard to light.
 There have been a number of people who have replaced the gill system with
 the IRIS system, and the conversion is fairly simple.  One thing to keep in
 mind is that there are two different types of systems for controlling the
 IRIS.  The original system found on most Sukhoi 26's and their ilk used two
 cables in semi hard tubes that each fed to a round wheel on the IRIS itself.
 In the cockpit there is a control LEVER that pulls on one cable at a time...
 obviously as you pull on one cable (and put it into tension) the other moves
 backwards and is slack and at that point the wheel on the IRIS pulls keeping
 it taught.   Just picture two cables attached 180 degrees apart to the outer
 rim of a wheel and you'll get the picture.
 The newer method (and more  preferable by far) is found on the newer SU-31's,
 and uses a HARD TUBE PUSH/PULL ROD very close to what controls the original
 YAK prop and gills.  If you get the NEWER IRIS, you should be able to use
 the existing YAK control that comes on the aircraft that used to control
 your gills.
 Ok, now the bad news.
 My YAK-50 came with the Les Crowder big spinner mod. (I mean as in HUGE..
 looks good though, and I have been told that this is really a YAK-18T
 spinner, but I don't know for sure).  Anyway, this mod required all the
 gills to be removed.
 So, when I originally bought the aircraft, it had 110 hours on it since new,
 and away I went... no gills, no problem, who cares anyway?
 After about 150 additional hours or so, I started getting all sorts of
 cracking on the cowling leading edges.  Then the hollow tubes that the front
 of the top and bottom cowling are riveted to, started cracking too.  This
 problem became mor  e  serious as time went on, because at the same time, the
 little red tubes/struts that hold the cowl MOUNTING ring in place started to
 crack and break TOO!  These are the little adjustable things that bolt to
 the front of each cylinder and go straight out to the cowl mounting ring.
 At the time, I could not imagine what was causing all this.  When my cowl
 was closed, it closed fairly firmly on the front cowl ring I just described
 above.  I thought this might be the problem so I loosened everything up.
 Wrong Answer. The problem got worse.
 I put soft fabric material between the mounting ring and the cowl ring....
 this helped a little, but it could still easily be seen that things were
 just vibrating too darn much.  I might also mention that my two bladed prop
 was also out of balance quite a bit.  Balanced the prop.... and that helped,
 but did not STOP the problem.
 I then got the chance to study a YAK-52 up close and personal  , and  could see
 that those gills added quite a lot of support to that front cowl ring.  So,
 I made four adjustable struts out of stainless steel tubing.... identical in
 design and function to the ones coming straight out from the cylinder
 attachment points, but for these... I ran them out from the front of the
 engine supercharger cover (using the same mounting studs that the IRIS would
 Result?  Problem cured.  No more cowling damage... problem is 100% FIXED.
 This leads me to advise AGAINST putting an IRIS system on a YAK-50/52,
 UNLESS you also take additional steps to support that front cowl ring.
 There are a lot of other factors involved here... such as: "What condition
 are your engine mounting rubbers in?"  Bottom line, the front of the cowls
 MUST MOVE   WITH  THE ENGINE, and if you take out the gills, you basically have
 a situation best pictured by imagining a person holding a HULA-HOOP out in
 front of himself with outstretched arms.  Then picture something/ANYTHING,
 "hanging from the hula-hoop itself"... you can see, there just is not any
 structural strength in that kind of assembly.  Put the gills in, and mount
 the gills to the engine itself, and you can see that the above picture
 regains all of its strength.
 By the bye, this is yet another reason to keep those leather mounting pads
 in good condition that are located on the engine itself.  These ALSO provide
 quite an amount of structural support to the whole upper and lower cowl.
 Sorry for the long post, but the details were needed in my opinion.
 Mark Bitterlich
 N50YK
 Here are some other interesting things that I learned the hard way about...
 last week!
 p.s.  Another tid bit for the YAK list.  The YAK-52  /50/55  and the
 Sukhoi-26/29/31 AND the CJ-6, all use the exact same piston in the
 air-compressor relief valve.  This piston and seal are what you adjust to
 control the peak pressure in your air system in the aircraft.  Doug Sapp
 sells the whole assy. for the CJ.... and you can take it right apart, take
 out the piston and spring (and locking nut) and put the whole mess into your
 YAK, if you want to do that instead of repair what you have with a new
 rubber bushing.  Here's the TID BIT:  The YAK-52W (and I am GUESSING the
 YAK-52TW as well) has a DIFFERENT PISTON in the pressure relief assy.  It is
 slightly BIGGER and is NOT a direct replacement with all the others
 mentioned earlier. Why not?  Go figure.
 p.p.s.  YAK-52W guys... did you know that there is an emergency pressure
 relief valve behind the seat that allows you to eliminate emergency air
 pressure to the landing gear without having to crack fittings and jack and
 cycle the gear, i  f you  ever do happen to open the emergency bottle valve?
 p.p.p.s.  For those aircraft with the manual engine starting valves (YAK-55,
 Sukhoi's) be aware that the rubber replacement tab for the starter valve
 MUST have a whole cut in the middle of it.  Ignore that fact, and the lever
 will work a few times and then fail forever. Trust me on this and save
 yourself a lot of head scratching.
 | |  |  | - The Matronics Yak-List Email Forum - |  |  |  | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:http://www.matronics.com/Navigator?Yak-List
