nuckollsr(at)cox.net Guest
Posted: Fri Feb 16, 2007 7:20 pm Post subject: Will SVLA charge on a sustaining voltage? |
After a 3.0A discharge to 11.0 volts where the battery
delivered at total of 11.2 ah of capacity, I connected
the battery to a 13.0 volt power supply and waited 18+
hours until the 're-charge' current was down to under
30 milliampers.
A subsequent 3.0A discharge produced only 8.8 AH of
useful output. The same battery is back on a Battery
Tender Jr for another charge/discharge cycle.
This experiment suggests that there's something to
the notion of carrying the battery's recharge profile
up to the point where rate-of-change for voltage takes
the upward inflection which is the battery's way of
letting the outside world know that it's getting pretty
close to full.
( IF one aspires to be "world class", )
( what ever you do must be exercised )
( EVERY day . . . )
( R. L. Nuckolls III )
klehman(at)albedo.net Guest
Posted: Sat Feb 17, 2007 9:33 am Post subject: Will SVLA charge on a sustaining voltage? |
I always deal with partially discharged batteries rather than fully
discharged ones but I have probably waited at least a couple of days to
notice the recharge current to fall to the float current and that is
typically under 10 ma depending on the battery. The actual energy under
that upward inflected curve is small but it still takes awhile to get
the equivalent at very small charging current of course. I use 13.5
volts for AGM batteries which probably helps. 13.5 is more in line with
what I've seen on things like burglar alarms and small UPS batteries.
Someone will no doubt mention that there is more to this than just
restoring a full charge though. Below is a repeat of a very good post
out of the archives which suggests that charging with that voltage
inflection is a good thing for storage batteries that don't get a bit of
overcharging in a vehicle. It might also give a possible reason why
pulse charging might have some benefit even if the desulphation theory
is bunk. The strong inflection that shuts off the built in charger on
my booster battery pack is a better scheme for frequently used batteries
and probably for VRLA batteries in general. That $30. booster battery
pack has a 15AH battery and it often runs a 120vac inverter and it also
makes a handy (less than an amp) charger by just clipping it onto
another battery and plugging it in to let them both charge in parallel.
Ken
There are four main reasons why AGMs wear out.
1) Loss of electrolyte
2) Grid corrosion
3) Sulfation
4) Paste degradation
If you overcharge an AGM excessively, it will lose electrolyte and
dry out. This is NOT why they wear out in airplanes and cars (typically.)
Typically, AGMs go bad because they are not properly charged. If you
don't over charge them a little bit on a regular basis, the negative
plate gets further and further behind the positive plate. The negative
plate then sulfates and you lose capacity and cranking power. (In the
short term, you lose capacity simply because the negative plate is not
fully charged.)
Why you don't need to add water to an AGM is that the oxygen and
hydrogen gas recombine in the separator to form water. This
recombination process is not 100% efficient, and it causes the negative
plate to take slightly less charge than the positive plate when you
re-charge the battery. Each cycle gets the negative plate a bit more behind.
Occasionally, you need to purposely overcharge the battery to let the
negative plate catch up with the positive plate. A couple times per
year, you bring the battery up to 14.8 volts and let the current taper
off to less than an amp. You then push in a constant current of about 4%
of the amp-hr rating of the battery for about an hour. This cleans off
the negative plate.
High-end voltage regulators do something like this (like on boats
and motor homes). Every time you start up the engine, it charges up the
battery to normal voltage, then it gives the battery a slight overcharge
for a few minutes. Makes the big expensive AGM batteries last much longer.
>>>> What causes the other types of failures, just in case you wanted
to know. <<<
Excessive overcharging will cause the loss of electrolyte. Severe
discharge, causing reversal of a cell or two, will also cause
electrolyte loss.
Grid corrosion occurs if you leave the battery on float for a long
time. The oxygen gas formed eats at the grids that support the paste.
Sulfation is caused by leaving the battery discharged for extended
periods of time. Not fully charging the battery and leaving that way
will also cause sulfation.
Paste degradation is caused by repeated severe and/or deep
discharges. Cranking the battery flat over and over is a good way to
cause paste degradation.
Robert L. Nuckolls, III wrote:
Quote: |
<nuckollsr(at)cox.net>
30 milliampers.
close to full.
William.P.Dube(at)noaa.go Guest
Posted: Fri Feb 23, 2007 10:13 am Post subject: Will SVLA charge on a sustaining voltage? |
To charge a lead-acid battery 100%, you must go to to at least 13.8
volts. It will take _forever_ at this voltage. To charge it more
quickly, and to help remove any sulfation, you have to go above 14
volts. Ideally, you would want to go to 14.7 volts (or a bit more,) let
the current taper off, then go to 13.8 volts to maintain the charge.
Bill Dube'
30 milliampers.
close to full.
( EVERY day . . . )
