snaps(at)gotricounty.com Guest
Posted: Fri Feb 16, 2007 6:28 am Post subject: belly radiator needed |
Looking for old style belly radeator
GENTRYLL(at)aol.com Guest
Posted: Fri Feb 16, 2007 7:49 am Post subject: belly radiator needed |
I think there is a Rotax version that just came out in Ebay Aviation Parts.
kitfox(at)ida.net Guest
Posted: Fri Feb 16, 2007 8:20 am Post subject: belly radiator needed |
I have an orig. nsi copper radiator.
Albert
wingsdown(at)verizon.net Guest
Posted: Fri Feb 16, 2007 9:27 am Post subject: belly radiator needed |
If you look on line there are several companies that will custom fabricate you a radiator to meet the needs of your engine and type of coolant. You can get as fancy or simple as your budget allows.
Rick
