Pitot Geometry
kuffel(at)cyberport.net
PostPosted: Fri Feb 03, 2006 8:31 am    Post subject: Pitot Geometry Reply with quote
Sorry, I forgot a topic line.
Bob Bean:
<<That same effect is what will make me reform the front of my handmade
aluminum nose cone. At easy cruise and below the airspeed works ok.
If I crank it
up the nose tips down and the ASI starts doing a little dance.
The probe is located 15" back of the front and 3 1/4" standoff from the
bottom.>>
First you might try an old trick in reverse. If your pitot tube is really
a tube, file the front at at angle to form a scoop. For your case the
lower edge of the tube would be forward.
Filing the front of the tube with the upper edge forward has sometimes
helped with wing mounted pitots which had abnormally low indicated
airspeeds at stall. Doing the opposite might help and certainly is easier
to try than a new nose cone.
Tom Kuffel
Whitefish, MT
Building Original FireStar
Richard Pike
PostPosted: Fri Feb 03, 2006 8:55 am    Post subject: Pitot Geometry Reply with quote
Move it about 15" forward and a bit down. If your pitot tube and static
air openings are about even with the front of the nose bowl, and at
least 6" below it, it will work perfectly.
Here is an example:
http://www.bcchapel.org/pages/0003/pg7.htm
Richard Pike
MKIII N420P (420ldPoops)
If I crank it
bottom.
The air should be linear at that point, fast or slow.
Eventually I may know how fast I'm going.
-BB
On 3, Feb 2006, at 2:26 AM, kuffel(at)cyberport.net wrote:
> DVD asks:
> <<don't need the "tube" because the bulkhead fitting is forward of the
> nose about 7/8" and should be in undisturbed air?>>
> As in most things aeronautic, "not exactly". 7/8" in front of the
> wing or
> nose cone the air is relatively undisturbed *relative to the surface*.
> In
> other words, almost static. Unfortunately, what you need to measure is
> air undisturbed relative to the ground (+/- wind of course). The
> general
> rule is to reach such air you should be as far away from the nearest
> surface as the radius of curvature of that surface.
Richard Pike
Kolb MKIII N420P (420ldPoops)
Kingsport, TN 3TN0
slyck(at)frontiernet.net
PostPosted: Fri Feb 03, 2006 12:22 pm    Post subject: Pitot Geometry Reply with quote
Thanks guys, all good food for contemplation. My nose cone front end
is a hole plugged with blue foam, coated with glass and epoxy.
It has been redone with my big grinder once before.
I made my pitot from a piece of very thinwall stainless tube figuring
the shear effect would possibly give me more accuracy. Pretty tough
to bend without a wrinkle. Just fanciful thinking on my part,
but scrap is cheap.
I would like to get it up where its safe though, I have a tendency to
go where no man has gone before. (the brush)
-BB do not archive
Here is an example:
Richard Pike
> If I crank it
> the
> bottom.
> -BB
>> DVD asks:
>> the
>> wing or
>> surface*.
>> In
>> is
>> general
PostPosted: Fri Feb 03, 2006 4:53 pm    Post subject: Re: Pitot Geometry Reply with quote
Hi Bob: You did not clarify if that excursion to the brush was controlled, intentional, or uncontrolled and unintentional.
flht99reh(at)netzero.net
PostPosted: Fri Feb 03, 2006 6:35 pm    Post subject: Pitot Geometry Reply with quote
John, the question you asked below reminded me of an instructor in a
Salesman course on successful salesmanship (I believe for those that care
that it was the Larry Wilson Salesmanship Course). He said there are four
categories of salesmen (or for that matter, any area of interest): The
highest is the conscious competent. This one is aware that there successful
and why. Then there is the unconscious competent. This one, he says, has no
idea why they are successful. Then the third: the conscious incompetent.
This individual is aware of why they are not successful. Then the last: the
unconscious incompetent. He or she, has no idea why or the fact that they
are unsuccessful.
I was, for a great deal of my career, an unconscious competent. I had the
way to sell refrigerators to Eskimo's; I just never understood why they
bought from me. Now over my life I have graduated to being the conscious
incompetent. I know that I know that I am a complete, in every way failure.
But soon, I hope to acquire that happy medium most elderly men achieve: the
full blown unconscious incompetent. Imagine, being able to fail with dignity
in your own eyes! Now I don't want to be in that category while flying, just
in all other matters. I mean that would complete for me the whole circle of
life: I wear glasses, my speech gets slurred on just six or eight beers, my
hearing is attuned to hear only Harley Davidson motorcycles with drag pipes,
I walk with a limp, have high blood pressure, have record setting high
cholesterol, thyroids are out of whack and I could afford to loose thirty of
forty pounds.
The real Ralph from Ohio!
Kolb 1990 Firestar KXP
hauck's holler, alabama
DO NOT ARCHIVE!!!
David.Lehman
PostPosted: Fri Feb 03, 2006 8:00 pm    Post subject: Pitot Geometry Reply with quote
OK Ralphie...
I nominate you for President of our ol' man's club... I think most of us
are a lot like you...
DVD
successful
no
the
are unsuccessful.
failure.
the
dignity
just
of
my
pipes,
of
forty pounds.
controlled,
DO NOT ARCHIVE!!!
ô¿ô
"Both optimists and pessimists contribute to the society. The optimist invents the aeroplane, the pessimist the parachute."
--- George Bernard Shaw
pj.ladd(at)btinternet.com
PostPosted: Sat Feb 04, 2006 3:40 am    Post subject: Pitot Geometry Reply with quote
least 6" below it, it will work perfectly.>>
Gosh!, and all this time I thought it was just a matter of putting the pitot
where the cows didn`t knock it off.
Cheers
Pat Smile
PostPosted: Sat Feb 04, 2006 12:49 pm    Post subject: Pitot Geometry Reply with quote
Davey, I would be most honored, and as such would delegate you as V.
President. As such, your first duty would to be to inform me as to what I am
to preside over!
Please, Please do not archive, as I probably would forget where to find it.
And yes, I know this demeans the value of the web site by carrying on site
such drabble. But then 'I am the President!
