bbradburry(at)allvantage. Guest
Posted: Wed Feb 14, 2007 3:51 am Post subject: What should I check? |
I am wiring my plane like Z-19. I currently only have one battery
installed in the engine battery position. Yesterday I had the engine
master switch on, and thinking that if I wanted to charge the battery
while the engine was running, I would need to turn the main master
battery switch to alternator. I had not yet started the engine.
When I switched the main master to alternator, I heard a series of rapid
clicks and thought that I saw some smoke drift over the panel. I
immediately turned it off.
Later on inspection I discovered that I had not connected the ground
wire to pin 1 of the main master switch. (what a dope!)
I have not been able to discover any burned wires or parts. What did I
probably burn up? Can someone direct me to the probable areas to check?
Bill B
nuckollsr(at)cox.net Guest
Posted: Wed Feb 14, 2007 6:45 am Post subject: What should I check? |
At 06:52 AM 2/14/2007 -0500, you wrote:
Quote: |
<bbradburry(at)allvantage.com>
while the engine was running, I would need to turn the main master battery
Later on inspection I discovered that I had not connected the ground wire
Impossible to deduce from the information you've provided.
If and open ground wire to the master switch were the only
problem, you would not have closed the battery contactor
and things should have been "black". If you had power on
the airplane after having moved the switch, then the battery
contactor had to be closed. This suggest wiring errors that
go beyond the one you cited.
When powering a system up for the first time, I'll suggest
that folks pull all the fuses (or open all breakers) and check
to see that battery contactors operate as expected. If you're
needing to use batteries as the source of first power (as opposed
to a plug-in-the-wall power supply) then it's a good idea to
replace the battery-to-master-contactor jumper with a temporary
in-line fuse holder. Put a 5A fuse in to energize contactors,
power up fuse-less busses, etc to see that voltage is getting
to where it belongs. Then increase the battery fuse size and
begin brining things on line one fuse or breaker at a time.
That's another nice thing about fuseblocks . . . you can power
up circuits for the first time with undersized fuses . . . this
can be a smoke-free technique for checking out complex control
circuits like landing gear indicator lights, control contactors,
etc. You should be able to check out the vast majority of systems
in your airplane, one-at-a-time with no more than a 10A fuse
in series with the battery.
Only after you're satisfied that there are no "holes for
smoke to escape from" do you replace the fuse-jumper with
a fat wire so you can crank the engine and run the alternator.
Better yet, acquire a plug-in-the-wall power supply like
http://tinyurl.com/23nf7m
These are readily available in a variety of sizes. I used
to sell a 25A device off my website. These are current limited
supplies that will shut down for heavy shorts. You can use the
series-fuse technique for first-power on systems with very
light loads.
For the vast majority of builders, the battery
is their #1 source for test-energy . . . cheap, reasonably
reliable and it's part of the finished system.
Unfortunately, the battery is most able and willing to
dump hundreds of amps into a mis-wired system and
the outcomes are never happy. If you haven't added
a small, first-power-friendly supply to you suite of
shop tools, then at least get an inline fuseholder
to build a temporary firewall between your battery and
potentially fragile wiring mistakes.
