mitch(at)skybound.com Guest
Posted: Tue Feb 13, 2007 1:18 pm Post subject: NAV audio hum - simple question |
I've verified the hum coming out of the Garmin 430's NAV 1 audio hi pin
(on connector 4006), it has peaks at 500 and 1500 Hz, and is 60
millivolts when measured with an oscilloscope. Many people won't care
about this because they have audio panels and the NAV audio is typically
turned off all the time unless you're identifying a VOR. I care,
because I don't have an audio panel and my NAV 1 audio is always present
(mixed by Bob's Iso Amp with COM audio, marker beacon, and traffic
warnings). I can knock down the level of the hum a little bit with a
T-Pass filter of sorts: two 500 ohm resisters with a 100 pF cap going to
ground in the middle. I have hi-buck Bose-X noise canceling headphones
and stereo music, and here is the million dollar question:
Will a 60 millivolt hum into an intercom be audible when the engine is
running?
If so, my choices are
1) return the unit to Garmin for testing/fixing (hopefully), might have
a bad capacitor on board or something, or it might be considered
"normal" by them, in which case I've just wasted two weeks.
2) put the nav 1 audio on an on/off switch on the instrument panel,
which I would like to avoid.
Thanks for any educated responses!
Mitch Faatz RV-6A Never Ending Finish Kit Auburn, CA
Bill Denton
Joined: 10 Jan 2006 Posts: 97 Location: Chicago, IL USA
Posted: Tue Feb 13, 2007 1:29 pm Post subject: NAV audio hum - simple question |
As a short-term solution, why not just turn off NAV audio by pushing the
VLOC volume knob? Or you can just turn down the volume with the same knob.
Posted: Tue Feb 13, 2007 2:09 pm Post subject: NAV audio hum - simple question |
The hum is present with the NAV audio all the way down.
john(at)ballofshame.com Guest
Posted: Tue Feb 13, 2007 2:23 pm Post subject: NAV audio hum - simple question |
Maybe I'm not envisioning this right (my mind is fried trying to get
through a bug at work) but the filter you described sounds like a low pass
filter. I think you would want a high pass filter assuming that you don't
ultimately track this down to some other problem somewhere else.
Like I said, I could just be thinking about it all wrong due to not enough
coffee and too much thinking today
-John
www.ballofshame.com
<mitch(at)skybound.com>
running?
Bill Denton
Posted: Tue Feb 13, 2007 2:28 pm Post subject: NAV audio hum - simple question |
If you are not getting any "nav audio" with the volume knob turned all of
the way down, one would suspect that the problem lies outside of the
radio...
Posted: Tue Feb 13, 2007 2:51 pm Post subject: NAV audio hum - simple question |
Never mind. You definately don't want to get rid of 500hz and 1500hz.
LOL...divide by 10 problem on my end.
Where's my coffee?....
-John
www.ballofshame.com
-John
www.ballofshame.com
> running?
nuckollsr(at)cox.net Guest
Posted: Tue Feb 13, 2007 4:21 pm Post subject: NAV audio hum - simple question |
At 01:16 PM 2/13/2007 -0800, you wrote:
turned off all the time unless you're identifying a VOR. I care, because
I don't have an audio panel and my NAV 1 audio is always present (mixed by
Bob's Iso Amp with COM audio, marker beacon, and traffic warnings). I can
knock down the level of the hum a little bit with a T-Pass filter of
sorts: two 500 ohm resisters with a 100 pF cap going to ground in the
middle. I have hi-buck Bose-X noise canceling headphones and stereo
running?
1) return the unit to Garmin for testing/fixing (hopefully), might have a
bad capacitor on board or something, or it might be considered "normal" by
2) put the nav 1 audio on an on/off switch on the instrument panel, which
Hmmmm . . . you may well be experiencing one of those
unforeseen consequences of quantum technology jumps.
For years, I've been able to sit in cockpits of some
REALLY expensive airplanes and hear things in the phones
that (to my way of thinking at least) shouldn't be audible.
Indeed, once the engines are running and you've got wind
noise blowing over the the fuselage, the ambient noises
overpowered the offending noises.
More than one customer has complained about hearing
things they'd never heard before after installing a
good noise cancelling headset system. It may be that
Garmin will readily admit to the "noise" being
present but still well within any published signal
to noise ratio specifications. Those frequencies sound
like they might be associated with the "AC" voltages
needed to drive LCD screens.
If push comes to the hard place, it may take a couple
of notch filters to attenuate them to acceptable if
not inaudible levels. I'll have to remember to ask
the customer support techs if they've had any cases
of unacceptable noise level complaints resulting from
the installation of super headsets!
( IF one aspires to be "world class", )
( what ever you do must be exercised )
( EVERY day . . . )
( R. L. Nuckolls III )
