Static Air System - Alternate Air Valve
rvreynolds(at)macs.net
PostPosted: Mon Feb 12, 2007 4:13 am    Post subject: Static Air System - Alternate Air Valve Reply with quote
Does anyone have a source or suggestion for the alternate air valve
like the "real" planes have?
Richard Reynolds
LloydDR(at)wernerco.com
PostPosted: Mon Feb 12, 2007 7:03 am    Post subject: Static Air System - Alternate Air Valve Reply with quote
My Real RV10 has an alternate air source, I used the kit for the static
system from Safeair, and included the alternate option. But I do not
know if the RV10 is real enough for you?
Dan
N289DT
apilot2(at)gmail.com
PostPosted: Mon Feb 12, 2007 7:37 am    Post subject: Static Air System - Alternate Air Valve Reply with quote
A lot of "unreal" type certificated aircraft are certified for IFR
without an alternate static source. Both TC aircraft I have owned fit
that description.
Richard Reynolds
rleffler
PostPosted: Mon Feb 12, 2007 8:05 am    Post subject: Static Air System - Alternate Air Valve Reply with quote
My Cherokee has the same valve for an alternate static source as the fuel quick drain valves. I don't recall their name, but I can look it up when I get home. I paid like $75 dollars to get it from Wentworth, so I was sure to installed the OEM part, but was disappointed when I saw what the valve actually was and could have bought the same valve (although not with the appropriate Piper p/n#) from my FBO for about $10.
In looking at the Safeair alternate, while it appears to be quite easy to remove the plug, how easy is it to blindly replace the plug for testing?
The valve on my Cherokee can open and close blindy with one finger. The valve is just under the dash by my knee.
Date: 2007/02/12 Mon AM 10:02:53 EST
Subject: RE: Static Air System - Alternate Air Valve
Dan
N289DT
Bob Leffler
N410BL - Phase I
http://mykitlog.com/rleffler
steveadams
PostPosted: Wed Feb 14, 2007 5:48 am    Post subject: Re: Static Air System - Alternate Air Valve Reply with quote
http://www.asapmachineryrepair.com/airvalves2.htm
I put a similar 3 port valve in my panel. It is simple, accessible, and easy to use.
sam(at)fr8dog.net
PostPosted: Wed Feb 14, 2007 9:05 am    Post subject: Static Air System - Alternate Air Valve Reply with quote
To bad they need a $75.00 min order. Looks like a good solutin to the
alternate air problem.
http://forums.matronics.com/viewtopic.php?p=94958#94958
CJohnston(at)popsound.com
PostPosted: Wed Feb 14, 2007 2:54 pm    Post subject: Static Air System - Alternate Air Valve Reply with quote
This is super cool. Can you give details? Which part number? did you
use the 10-32 threaded one? the MTV-3? I think I want my mtv. And
some more info!
cj
#40410
fuse
www.perfectlygoodairplane.net
mike(at)learningplanet.co
PostPosted: Wed Feb 14, 2007 6:33 pm    Post subject: Static Air System - Alternate Air Valve Reply with quote
I was intrigued as well, so a little searching and I found this:
http://www.clippard.com/store/display_details.asp?sku=MTV-2P
1/8" NPT on the back. That should make a really nice alternate air
source selector. Price: less than 12 bucks.
Mike Schipper
#40576 - Wings - www.rvten.com
On Feb 14, 2007, at 4:53 PM, Chris Johnston wrote:
<CJohnston(at)popsound.com>
you
some more info!
cj
#40410
fuse
LarryRosen
PostPosted: Wed Feb 14, 2007 6:48 pm    Post subject: Static Air System - Alternate Air Valve Reply with quote
Here is the clippard catalog
<http://www.clippard.com/downloads/general/PDF_Documents/2006%20Catalog/Catalog%20by%20Section/2-Way%20Control%20Valves.pdf>
I was thinking the TV-2SP
$9.03 or $9.85 with epdm seals. But the catch $5 handling and $10 shipping.
$25 makes a pretty slick alternate air set up.
Larry
Michael Schipper wrote:
<mike(at)learningplanet.com>
Mike Schipper
> some more info!
> Thanks
> cj
> #40410
> fuse
Larry Rosen
#40356
N205EN (reserved)
<http>
patrick.pulis(at)seagas.c
PostPosted: Wed Feb 14, 2007 8:37 pm    Post subject: Static Air System - Alternate Air Valve Reply with quote
Michael, I too am interested in acquiring one of these valves and would
be prepared to send you the funds for purchase of an additional valve
with your order, inclusive of costs for shipping downunder.
Patrick Pulis
Adelaide, South Australia
#40299
DO NOT ARCHIVE
steveadams
PostPosted: Thu Feb 15, 2007 5:32 am    Post subject: Re: Static Air System - Alternate Air Valve Reply with quote
some more info!
cj
#40410
fuse
Mine actually came with my kit (no, I'm not an RV-10 builder), and I'm sure that you can get one cheaper from one of the suppliers listed above. Mine has 2 threaded fittings (static line in and static line out), and an unthreaded opening. In the normal position pressure from the static port just passes through the valve. In the alternate position, the line out is opened to cabin pressure. You could probably also use a valve with a single threaded fitting and T it into the static line.
 Filesize:  51.75 KB
 Viewed:  524 Time(s)
 Filesize:  28.9 KB
 Viewed:  542 Time(s)
