| cpayne(at)joimail.com Guest
				|  Posted: Thu Feb 02, 2006 12:33 pm    Post subject: gear problems |   |
				| Terry,
 Perhaps it was a bit of dirt/goop/whatever....or you just bled that line down for now. I put new restrictors in the gear lines; at BOTH ends, actuators and valves. However I sized the holes at .040" to reduce the chance of small pieces of grit clogging a line. Also put one on the handle side of the up lines.
 No more "Wham" down into lock , just a slow, orderly transit to the lock position and then a "snick" as all lock at the same time. OTOH, the nose still seems to lag on the gear up swing.
 Craig Payne
 | |  |  | - The Matronics Yak-List Email Forum - |  |  |  | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:http://www.matronics.com/Navigator?Yak-List
