Rear Former Fix
naumuk(at)alltel.net
PostPosted: Sun Feb 11, 2007 3:25 pm    Post subject: Rear Former Fix Reply with quote
HDS People-
Attached is a shot of my rear former after adjustments. (It's fuzzy, I know). Note the top flange is the same configuration as the bottom. Also note that the longerons are right on track and the level bubble is centered.
3 hours to put things right, but zero outlay. New builders might want to set up after the side skins are on and make adjustments as necessary.
Bill Naumuk
HDS Fuselage
Townville, Pa
 Filesize:  40.99 KB
 Viewed:  262 Time(s)
gboothe5(at)comcast.net
PostPosted: Sun Feb 11, 2007 7:00 pm    Post subject: Rear Former Fix Reply with quote
Thanks for the heads-up, Bill.
Gary Boothe
Cool, CA
601 HDSTD, WW Conversion 90% done,
Tail done, wings done, working on c-section
From: owner-zenith-list-server(at)matronics.com [mailto:owner-zenith-list-server(at)matronics.com] On Behalf Of Bill Naumuk
Sent: Sunday, February 11, 2007 3:25 PM
Subject: Rear Former Fix
HDS People-
Bill Naumuk
HDS Fuselage
Townville, Pa
