Introduction To List - Thanks & Spreadsheet
james.s.clark(at)comcast.
PostPosted: Sat Feb 10, 2007 9:04 pm    Post subject: Introduction To List - Thanks & Spreadsheet Reply with quote
Hello again all,
Thanks for the responses. I have tried to combine new questions and
responses to others questions here to save list traffic...
Research is the best part of getting ready for this...I'll bet I
already have 300-400 hours and only a DVD from Vans purchased so far...
Jesse-Thanks, I appreciate the advice to save on the panel at first.
I'll work on trimming that to a minimal IFR platform with glass that
can be grown without buying anything in panel that later gets out-ed
by something else.
Kelly-Thanks, the 32k already included the TruTrak digiflight-II VSGV
and a Garmin 496 in the airgizmo mount.
Russ-Actually, I was looking at 3 screen Horizon 1 with 2x AHRS (I'm
a timid IFR pilot who likes backup). Although this is what I have
spending the most time looking at recently...no matter how much I
read the cross connects and interconnects in the GRT documentation, I
can't get a clear picture of how it would work with: (Horizon1
GRTSport Horizon1) as you have it. Doesn't that limit the HSI from
being on the 2nd screen where you want it? I'll probably have lots
more questions for you to help me in this area in the coming weeks.
Please tell me what is overkill and what makes sense: 3 Horizon (each
with a 5H WAAS GPS) & 2 separate AHRS? I see now that you can buy a
second AHRS one in the same box for only 1500. Is this any less
redundant? Your panel has been one of my "mentors" Smile. Why did you
choose the sport & the middle location instead of position #3 for the
sport? Thanks. If I get 2 of the Horizon1's each with internal WAAS
5Hz GPS, I assume I have to run 2 antennas. 3 internal gps's would
probably be nuts right?
Jeff- I'm located in northern VA.
Crazy ebay ad: Noticed the RV7 N-Number of ad posters neighbor/friend
is also visible in last picture in ad: N577AZ has address near
individual you listed so I think your little investigative work is
correct.
Attached is a spreadsheet I have spent weeks compiling (will probably
spend weeks more refining). I have one set of quantities shown but
would be interested in hearing others suggestions to add or subtract
specific items. This as it stands indicates price > 140k and that
worries me because I'm sure there is at least 10k of hidden costs as
indicated by Anh and Tim. I hope this spreadsheet might be useful to
someone. If others have spreadsheets / lists such as this it would
help me greatly to see them. Where can I save money in this list... Smile
Jim Clark
---Wishing 3 cheltons cost the same as 3 dynons...
RV10_Costs_(version_1).xls
 Filename:  RV10_Costs_(version_1).xls
 Filesize:  32 KB
 Downloaded:  280 Time(s)
Deems Davis
PostPosted: Sun Feb 11, 2007 5:10 am    Post subject: Introduction To List - Thanks & Spreadsheet Reply with quote
Jim
Some things to consider adding to your list.
1. Shipping, Not just for QB, but for Empenage, Finishing, FFW,
Engine, Avionics, etc. and the 20-50 additional orders that you will
place to Van's, Aircraft Spruce, etc. (it adds up!). Easily another $1-2k
2. Heated Pitot (IFR?) $400
3. Wiring. Harnesses; Are you going to do it yourself? Even so you will
have hundreds to thousands of dollars in wire, pins,connectors,
terminals, circuit breakers, switches, dimmers etc. Do you have the
tools to do the wiring crimpers, strippers, pin insertion/removal,
solder ? If not add at least a couple hundred more for these.
4. Replacement parts and shipping, you may be the only builder to do it
all right the 1st time, but if not you may have to purchase replacement
parts, packaging, shipping... (min several hundred $'s
5. Will you prime your aircraft? if so add cost of primer (not cheap)
and application tools. Will you paint the interior of your plane?
6. Interior? The front seats that Van's sends do not include even the
foam for cushions. Add $1k -$10k
7. Composite/fiberglass supplies epoxy, hardener, cloth, fillers,
thickeners, primers, and tools. (Fiberglass dulls/ruins metal working
tools very fast) There's more fiberglass on this kit than you would
suspect at 1st
8. Do you have an existing shop that is well equipped with tools? (e.g
2 different torque wrenches, compressor, spray gun/s, air hoses, ...),
The RV kits are just the additional tools that you will need. You should
think seriously about a pneumatic squeezer, or think about extending the
timeframe to build. There must easily be 20,000 rivets in the plane.
9. Not sure what you include in Firewall Forward accessories, but Van's
kit price exceeds your cost for this and the prop governor.
10. CHT & EGT probes and sensors and wiring harness.
12. A professional paint job After you are flying will likely cost you
at least $7-8K. and those that do it for RV's are booked a year out.
(You may be able to do it for less if you find someone locally and paint
the parts while you're building. but I talked with another builder a
couple of nights ago who went this route and it cost him $6-8k)
11. Have you considered the annual operating costs? Insurance alone will
likely run you $3-4k
When I was at a similar stage in my decision/planning process I thought
I could build and fly the plane for $129k. (that was 2 price increase
cycles ago) I've blown through that figure considerably, part of the
reason was I didn't anticipate some of the above, and the rest of the
reasons were decisions I made along the way that consciously added cost.
I think that virtually all of the people on this list will tell you that
their costs/ final estimates exceeded their original estimates by a
significantly greater margin than they originally anticipated. (I
finally got to the point where I quit updating my spreadsheet, because I
wanted to stay in a state of denial!). Just make sure that your
planning/decision process leaves some realistic contingencies available
if you miss your original budget. There's too much love and passion
that goes into building these things to see it lost/halted part way
through the process.
Deems Davis # 406
Finishing FWF - ( A Misnomer ! )
http://deemsrv10.com/
James S. Clark IV wrote:
Hello again all,
rv10(at)sinkrate.com
PostPosted: Sun Feb 11, 2007 7:58 am    Post subject: Introduction To List - Thanks & Spreadsheet Reply with quote
James,
I didn't see any mention of antennas. Here are some examples for
planning...
COM $149 x 2 CI-122
NAV $299 x 1 (VOR) CI-157C
XPDR $129 x 1 KA-61
-Ben
AV8ORJWC
PostPosted: Sun Feb 11, 2007 9:02 am    Post subject: Introduction To List - Thanks & Spreadsheet Reply with quote
Deems - you did a comprehensive and accurate assessment on the pursuit
towards reality cost of an RV-10. I might add that the modifications
that you made would be found by many as "Wow, I should have done that as
well". I think your review is balanced and accurate.
Tim might chime in on his final flying cost as well. Even Randy would
likely say finishing a flyable RV-10 for Jim's budget number is a long
shot. Let me acknowledge that several have done it on the cheap, but for
the lack of a nail, corners should not be cut. Choosing IFR makes the
budget an entirely different beast than the Day VFR Cruiser this was
supposed to be. Jesse could list exactly what things could be
considered to leave it "Upgradeable to IFR" well down the road.
It won't be a Cirrus but it will fit like a glove and be custom to your
needs, while still being much more fiscally realistic to operate. Take
the original VANS estimate of cost (2005 dollars), factor in the
increases in kit prices since then, add the % increase in engine cost in
just the last 36 months. Now project it out another 36 months. You
should be within 7% accurate.
John Cox
"Eyes Wide Open" through the entire process - 25% more than budget is
the norm.
#40600
jwt(at)roadmapscoaching.c
PostPosted: Sun Feb 11, 2007 5:20 pm    Post subject: Introduction To List - Thanks & Spreadsheet Reply with quote
Jim,
I am in Richmond. You are welcome to come down and look our 10 over.
John Testement
jwt(at)roadmapscoaching.com
40321
Richmond, VA
FWF, engine, wiring
robin1(at)mrmoisture.com
PostPosted: Wed Feb 14, 2007 10:26 pm    Post subject: Introduction To List - Thanks & Spreadsheet Reply with quote
Jim,
I may have missed it in the disussion but insurance is another
consideration. The -10 will probably be significantly more expensive to
insure; fortunately you get to split that cost too.
On the other side one day you will sell your plane. More likely
sooner rather than later when in a partnership. If you choose to build a
-10 I suspect that you will see more of your initial "investment" back
from a -10 than a fully loaded -7(A). (IMHO)
Robin
RV-4 Sold
Flying RV-6A 325 Hours
RV-10 in pieces
I have an unlimited budget & I expect to exceed it.
