Attaching Shield to "Lo"/Ground Wire at Intercom
bobair8(at)msn.com
PostPosted: Sat Feb 10, 2007 6:47 pm    Post subject: Attaching Shield to "Lo"/Ground Wire at Intercom Reply with quote
<?xml:namespace prefix="v" /><?xml:namespace prefix="o" /><![endif]--> The installation instructions for my PS Engineering PM1000II intercom show all shields for the mics and phones grounded to their corresponding "Lo" wires. I've looked at Bob's comic books and searched the collection of FAQs and couldn't find a way to do it. The wires will be crimped onto D-SUB pins so there is only room for one wire.
(For intercom installation wiring diagram, see http://www.ps-engineering.com/docs/pm1000wiring_data.shtml)
Can I "daisy chain" the shields as Bob shows in his "Shield Termination Techniques" comic book and ground them all to Ground Pin 1 (which goes to the "forest-of-tabs" ground block) rather than at each individual "Lo" wire pin?
Or should each shield be individually grounded to its corresponding "Lo" wire? It seems I could create an uninsulated length (~0.3 in) before the end of the "Lo" wire and lightly solder the shield directly to the "Lo" wire, cover it with heatshrink and then crimp my D-Sub pin to the end of the "Lo" wire and insert it into the connector.
GlaStar
Dennis Glaeser
PostPosted: Sat Feb 10, 2007 8:48 pm    Post subject: Attaching Shield to "Lo"/Ground Wire at Intercom Reply with quote
I took a solder-cup D-Sub female connector and soldered all the connectors
together and soldered one wire which went to the common pin on the intercom.
Then I put pins on all the shields and "Lo" wires and put them in a male
connector. At one time Bob had an article that showed this, but I couldn't
find it either.
Dennis Glaeser
RV7A
steerr(at)bellsouth.net
PostPosted: Mon Feb 12, 2007 8:12 am    Post subject: Attaching Shield to "Lo"/Ground Wire at Intercom Reply with quote
I'm in the same situation. Bob had given me a link at one time for this, but I can't find it. Also can't find anything in the articles on Bob's web site. Please let me know if you get a response to this.
Thanks very much..
Bill Steer
john_rv10(at)yahoo.com
PostPosted: Mon Feb 12, 2007 10:02 am    Post subject: Attaching Shield to "Lo"/Ground Wire at Intercom Reply with quote
Is this what you are after?
John Cleary
 Filesize:  74.9 KB
 Viewed:  225 Time(s)
