a.s.elliott(at)cox.net Guest
Posted: Thu Feb 08, 2007 10:21 am Post subject: Substituting fastons for connectors? |
Folks:
I have an ARC 459 transponder which uses a backplane connector which is no apparently longer made, and for which sockets are only available through a few sources at high cost. It appears to me that the .110 x .020 size faston receptacles would fit quite nicely on the existing pins. I would like to wire a DB-25 connector to the transponder using such fastons to make wiring it into rest of the plane a snap.
Anyone ever tried this before? If acceptable, the faston approach should also work nicely for the 359 and thereby open up a good source of inexpensive used transponders.
(I previously had a response suggesting that I wire the d-subconnector directly to the transponder circuit board. This seems less desirable to me.)
Andy Elliott, Mesa, AZ
N601GE (reserved)
601XL/TD/QB, Corvair, building...
