Ground blocks for RV's
brownrj
PostPosted: Mon Feb 05, 2007 4:36 pm    Post subject: Ground blocks for RV's Reply with quote
Is there any reason not to use copper as a ground plane or attachment point as opposed to the brass plate sold by B&C Specialties?
Ron
nuckollsr(at)cox.net
PostPosted: Mon Feb 05, 2007 6:46 pm    Post subject: Ground blocks for RV's Reply with quote
Ron
Brass was chosen for its solderability in attaching the
rows of fast-on tabs. Copper works too, just harder to
drill really round holes. Use a step-drill.
( IF one aspires to be "world class", )
( what ever you do must be exercised )
( EVERY day . . . )
( R. L. Nuckolls III )
jdalton77(at)comcast.net
PostPosted: Mon Feb 05, 2007 9:31 pm    Post subject: Ground blocks for RV's Reply with quote
I used copper - no real problems.
It was hard to solder the tabs - had to use a small torch.
Jeff Dalton
PostPosted: Tue Feb 06, 2007 10:14 am    Post subject: Ground blocks for RV's Reply with quote
I bought some great copper bars from McMaster-Carr. 2" high and 18" wide.
I riveted and the sweated the tabs on. Looks like hell, but works great.
Jeff
PostPosted: Tue Feb 06, 2007 10:20 am    Post subject: Ground blocks for RV's Reply with quote
At 11:43 AM 2/6/2007 -0500, you wrote:
<terrence_miles(at)hotmail.com>
I couldn't find any brass either. I am at this point in the install too. I
have some .06 copper bar 2" wide from a hobby store. I ordered it last
week. I plan on riveting and then sweating the tabs to the plate.
Go to any hobby shop or hardware store and look for this
display . . .
http://www.ksmetals.com/HobbyMerchandisers/default.asp
One of the products commonly found in these displays
is a hunk of brass about 4 x 6 inches. Anything .032"
or thicker is fine.
Any time you need heavier and larger pieces of brass,
check out the kick plates for doors at lumber yards.
pilot4pay
PostPosted: Tue Feb 06, 2007 1:06 pm    Post subject: Ground blocks for RV's Reply with quote
I have found sheet brass at the local Ace hardware. They may or may not have
some at Lowes or Home depot over in the hardware dept. I have seen some
hobbyist type material there. But generally it comes in narrower sizes as
Terry pointed out. Micro-mart comes to mind as a mail order source as well.
Craig Smith
Craig Smith
CH640 builder
SN: 0078
"Just think how stupid the average person is,
and then realize that half of them are even stupider!"
--George Carlin
lhelming(at)sigecom.net
PostPosted: Tue Feb 06, 2007 4:02 pm    Post subject: Ground blocks for RV's Reply with quote
I used the 48 tab ground block by B and C specialtyproducts. It is easy to
work with and I recommend it. I found I actually needed to double up on a
few due to needing more than 48 grounds on my VFR RV7 plane. It seems a bit
pricey, but it is rock solid and quick and easy to use. Indiana Larry
http://www.bandc.biz/cgi-bin/ez-catalog/cat_display.cgi?26X358218
Bret Smith
PostPosted: Wed Feb 07, 2007 7:32 am    Post subject: Ground blocks for RV's Reply with quote
Why wouldn't a brass door kick plate work...Like this
http://www.lowes.com/lowes/lkn?action=productDetail&productId=60593-81227-C6634SR-PL-R&lpage=none
Bret Smith
RV-9A "Wings"
Blue Ridge, GA
www.FlightInnovations.com
Bret Smith
RV-9A (Emp)
Bill Denton
PostPosted: Wed Feb 07, 2007 7:42 am    Post subject: Ground blocks for RV's Reply with quote
Don't know for sure, but I think those types of things are coated with
something to help prevent tarnish.
You might want to hit it a lick with a wire brush to assure good
conductivity...
Neal.George(at)hurlburt.a
PostPosted: Wed Feb 07, 2007 8:45 am    Post subject: Ground blocks for RV's Reply with quote
Exactly what I used...
Works great, lots of left-over stock for other projects.
Neal
RV-7 N8ZG (wiring - again)
Bret Smith
RV-9A "Wings"
Blue Ridge, GA
