nuckollsr(at)cox.net Guest
Posted: Sun Feb 04, 2007 12:21 am Post subject: Sharing ship's COMM antenna with the hand-held |
At 07:43 PM 2/3/2007 -0800, you wrote:
Quote: | Bob,
Re website with discussion on IC-ANT-SB
<http://www.flight.org/forums/showthread.php?t 74288>www.flight.org/forums/showthread.php?t 74288
Hmmmmm . . . the read I got on use of the
word "crude" was that he didn't think that a
3.5mm audio connector was well suited for
radio frequency coax transmission lines.
I note that Jim Weir weighed in on the topic
and rebutted someone assertions that use
of the wrong connector would introduce
significant loss. I didn't see anyone's
teardown analysis that went in to look at
the construction or robustness of the jack.
THIS is where the device will become troublesome.
Thanks for the link!
( IF one aspires to be "world class", )
( what ever you do must be exercised )
( EVERY day . . . )
( R. L. Nuckolls III )
Posted: Sun Feb 04, 2007 12:01 pm Post subject: Sharing ship's COMM antenna with the hand-held |
At 01:12 PM 2/4/2007 -0600, you wrote:
Quote: |
John, I don't think it's as simple as that.
If you put a 50 ohm resistor at the end of a piece of coax you are
transmitting into, the resistor becomes a "dummy load", and will heat up
to the extent that it is rated near the power level of the
transmitter. You cannot then simply add a T connector to another device
and assume that the dummy load will be invisible to the system.
If you connect a handheld radio with a 2W output into the receiver input
of a panel mounted radio, you'd better hope that receiver's input section
is capable of handling that level of power. I'm not sure any of them are.
I'm unaware of any aviation equipment manufacturer
that rates their products for ability to withstand
large doses of energy fed directly into the receiver's
input terminals. Unless you know that some radio you've
installed is so featured, be VERY CAREFUL how you hook
up any antenna changeover feature in your airplane.
A simple swap of coax cables on the ICOM hand-held
adapter would feed your hand-held's transmitter directly
to the antenna input of your panel mounted receiver.
All bets are off as to whether this would produce a
happy outcome.
N6030X(at)DaveMorris.com Guest
Posted: Sun Feb 04, 2007 12:11 pm Post subject: Sharing ship's COMM antenna with the hand-held |
Thinking outside the box is a good thing. At least the FAA allows it
in the experimental aviation world.
Dave
At 01:54 PM 2/4/2007, you wrote:
Yes, of course you're right Dave. I was just thinking out loud, I guess.
-John
>heat up to the extent that it is rated near the power level of the
>device and assume that the dummy load will be invisible to the system.
>input of a panel mounted radio, you'd better hope that receiver's
>input section is capable of handling that level of power. I'm not
>Dave Morris
>At 12:19 PM 2/4/2007, you wrote:
>><john(at)ballofshame.com>
>>If you short a 50 ohm resistor across the end of a 50 ohm coax,
>>you will effectively remove that "leg" of the cable from the
>>circuit so far as back reflection is concerned. This is called terminating.
>>Basically, the 50ohm resistor acts the same as an infinitely long
>>coax, if that makes sense?
>>So if radio manufacturers where clever, they would setup their
>>antenna inputs to short across a 50ohm load when the unit is off,
>>effectively terminating their end of the cable. On the panel, you
>>use a T with a 50 ohm terminator in the panel side. If you need
>>to use a handheld, you can turn off the panel mount and replace
>>the 50 ohm terminator with your handheld input. The downside is
>>that you will loose range.
>>Don't take any of this as a suggestion. It was just something
>>that flashed into my brain this morning when I thought about how
>>to make every compatible. I think this would work but you'd
>>sacrifice performance, so it's probably not viable.
>>-John
>>Doug Windhorn wrote:
>>><N1DeltaWhiskey(at)comcast.net>
>>>John,
>>>Not sure what you are getting at here, but simply measuring the
>>>in "resistance" of the antenna input will, I think, tell you little.
>>>Or, maybe I am missing what you are suggesting.
>>>Did a quick look at "characteristic impedance" on
>>>Wikipedia. When one talks about transmission cables (and
>>>matching connections), impedance is the "apparent resistance" to
>>>AC signals that the line is rated in, not simple resistance. I
>>>believe you are talking about measuring the impedance, not solely
>>>the resistance, of the input.
>>>I could surmise some thing about this, but probably make myself
>>>look a little (maybe a lot) unknowledgeable, so will leave
>>>further clarification to those with a better understanding of the subject.
>>>But a good starting place for discussion is to have an
>>>understanding of the relevant terms
>>>Regards,
>>>Doug Windhorn.
