Contactor
sam(at)fr8dog.net
PostPosted: Wed Jan 31, 2007 7:04 am    Post subject: Contactor Reply with quote
I'm ready to install my Radio Master contactor, just wondered if there is something better than the Van's heavy chunky solenoid that I used for the battery master. If I'm not mistaken I think it uses about an amp just to hold it closed, wouldn't a electronic version be much better, such as the PowerLink Jr. II 35A Solid-State Relay, listed on the Ecic Jones web site?
Sam Marlow
RV10 wiring
BobsV35B(at)aol.com
PostPosted: Wed Jan 31, 2007 7:24 am    Post subject: Contactor Reply with quote
Good Morning Sam,
Once again, this is way out of any area of expertise which I may have, but do I understand that you DO intend to have an Avionics Master Switch?
The last time I wired up such a device, I used a normally closed contactor.
The unit was wired in such a manner that the "On/Off" switch in the On position was open. In the Off position, the switch made contact and opened the master avionics contactor.
When the ship's master switch was off, the unit was unpowered and the master relay was closed. As soon as the aircraft master switch was turned on, the Avionics Master Contactor was powered and it opened the contactor leaving the avionics unpowered.
When I wanted to power the avionics suite, I flipped the switch to the ON position which took power away from the contactor. It closed and powered the stuff. Consequently, the only time the contactor used any power was when it was being held open during the time when I wanted the Avionics Buss unpowered.
In the event of a failure of the Avionics Contactor, it would most likely fail to the closed position thus giving me use of my avionics.
Worked for me!
Happy Skies,
Old Bob
AKA
Bob Siegfried
Ancient Aviator
Stearman N3977A
Brookeridge Air Park LL22
Downers Grove, IL 60516
630 985-8503
In a message dated 1/31/2007 9:06:26 A.M. Central Standard Time, sam(at)fr8dog.net writes:
Sam Marlow
RV10 wiring
sam(at)fr8dog.net
PostPosted: Wed Jan 31, 2007 8:00 am    Post subject: Contactor Reply with quote
Hmmm, something to think about. Where would I find normally closed contactor?
BobsV35B(at)aol.com (BobsV35B(at)aol.com) wrote:
[quote] Good Morning Sam,
Worked for me!
Happy Skies,
Old Bob
AKA
Bob Siegfried
Ancient Aviator
Stearman N3977A
630 985-8503
In a message dated 1/31/2007 9:06:26 A.M. Central Standard Time, sam(at)fr8dog.net (sam(at)fr8dog.net) writes:
Sam Marlow
RV10 wiring
BobsV35B(at)aol.com
PostPosted: Wed Jan 31, 2007 8:24 am    Post subject: Contactor Reply with quote
In a message dated 1/31/2007 10:04:01 A.M. Central Standard Time, sam(at)fr8dog.net writes:
Good Morning Sam,
The one I used was made by Essex Wire. I replaced it a few years later and found that division had been sold to Cole Hersee. I just looked in my Newark catalog and find neither Essex Wire or Cole Hersee listed!
A quick check has found several other manufacturers. One is Stancor and I am sure they would have something suitable. I guess the best thing to do is attack Google until you find what you want.
Happy hunting and,
Happy Skies,
Old Bob
AKA
Bob Siegfried
Ancient Aviator
Stearman N3977A
630 985-8503
nuckollsr(at)cox.net
PostPosted: Wed Jan 31, 2007 8:31 am    Post subject: Contactor Reply with quote
What's a radio master contactor? Do I presume correctly
that you're operating outside design goals and examples
cited in:
http://aeroelectric.com/articles/Rev11/AppZ_R11J.pdf
It's not completely clear to me how your proposed
radio master contactor fits into the overall system
In any case, few avionics loads need switchgear so
robust as a starter or battery contactor. For these
lighter loads, there are dozens of options for various
relays (mini-contactors if you will) that will handle
the loads . . . not the least of which is Eric's solid
state relay.
( IF one aspires to be "world class", )
( what ever you do must be exercised )
( EVERY day . . . )
( R. L. Nuckolls III )
PostPosted: Wed Jan 31, 2007 8:38 am    Post subject: Contactor Reply with quote
At 10:22 AM 1/31/2007 -0500, you wrote:
Good Morning Sam,
Buss unpowered.
An alternative to this approach is to craft an E-Bus
in the spirit and intent of any Z-figure. Then put
the AMS switch-relay in series with the normal-feedpath
diode. One gets all the advantages of the dual-feedpath
e-bus complete with isolation from the effects of
forgetting to open the master switch before closing
the alternate feed switch.
( EVERY day . . . )
PostPosted: Wed Jan 31, 2007 9:11 am    Post subject: Contactor Reply with quote
In the normally closed contactor catalog. However, I'll
suggest it will be easier to find if you call it a "relay".
Contactors are generally in the class of double-make, high
current ( >50A ) switching devices. What you're looking for
is something rated on the order of 20A. The catalogs are
replete with examples not the least of which may be seen
at:
http://dkc3.digikey.com/PDF/T071/1735-1738.pdf
http://tinyurl.com/2jfse2
http://tinyurl.com/2jey84
( EVERY day . . . )
sales(at)6440autoparts.co
PostPosted: Wed Jan 31, 2007 12:46 pm    Post subject: Contactor Reply with quote
They look like some of the ones seen on automobile applications. Has
anyone tried one of them ?
Randy
PostPosted: Wed Jan 31, 2007 1:47 pm    Post subject: Contactor Reply with quote
At 02:44 PM 1/31/2007 -0600, you wrote:
<sales(at)6440autoparts.com>
Has anyone tried one of them ?
Yup. Turns out that any part designed to survive under
the hood of a car is entirely suited for use in airplanes.
PostPosted: Wed Jan 31, 2007 2:54 pm    Post subject: Contactor Reply with quote
That's good to know. I have plenty of used ones around here but I think
I would opt for new ones (dang I hate it when my motto is "why buy new when
used will do") It may still be a good idea for all that use relays to pick
out a common type that is plentiful, may be good in a pinch.
Randy
PostPosted: Wed Jan 31, 2007 3:49 pm    Post subject: Contactor Reply with quote
think I would opt for new ones (dang I hate it when my motto is "why buy
new when used will do") It may still be a good idea for all that use
relays to pick out a common type that is plentiful, may be good in a pinch.
Randy
Don't get wrapped around the "reliability" axle for ANY
part selection. See chapter 17 for an expansion on the following
idea:
ANY PART can fail at any time irrespective of how many specs
define it or Q.A. processes have tested it. EVERY PART has
a service life . . . nothing runs forever.
Therefore, whether you pick a relay out of your junque box
in the shop or order it from Smiley Jack's High Dollar Parts
Emporium, do not depend on that part to never fail.
You do this by designing, maintaining and operating with
a goal of achieving failure tolerance. Failure tolerance
falls into two categories:
(1) getting on the ground without it is problematic and
could raise my blood pressure.
(2) getting on the ground without it is no big deal and
comfortable arrival at airport of intended destination is
a breeze.
If condition 1 applies, have a backup for it. Likelihood
of two category 1 failures on any single tank of gas is
pretty low . . . no matter how sleazy your parts supplier
is. So, pick any part to use anywhere but with a plan-B
designed into your system and operating procedures to cover
a category 1 failure.
A very reliable SYSTEM may be fabricated from rather
mediocre parts.
