Any 8's with firewall mounted oil coolers out there?
DONKEYVET(at)aol.com
PostPosted: Mon Jan 29, 2007 8:11 pm    Post subject: Any 8's with firewall mounted oil coolers out there? Reply with quote
Listers,
Has anybody out there ever sucessfully mounted an oil cooler on the firewall of an 8? If so do you have pictures? I saw one on a 6 today. Not sure if there is room on our firewalls but if so I would sure like to do it that way rather than on the back baffle.
Dennis Flosi
N963DF finishing kit
wally(at)blacksky.net
PostPosted: Mon Jan 29, 2007 10:09 pm    Post subject: Any 8's with firewall mounted oil coolers out there? Reply with quote
Check out Greg Hales RV8 web site under engine installation.
On Jan 29, 2007, at 11:09 PM, DONKEYVET(at)aol.com wrote:
Listers,
Dennis Flosi
crunk12(at)bellsouth.net
PostPosted: Tue Jan 30, 2007 5:04 am    Post subject: Any 8's with firewall mounted oil coolers out there? Reply with quote
Dennis,
I mounted mine on the right side of the firewall and have had no problems to date. I initially used the positech but quickley found that it did not work. I got the harrison/stewart warner 10599 and all has been well. I live near Atlanta and have flown my -8 out to Phoenix and back in July with no problems.
You will have to make a plenum for the top of the cooler. I tig welded an aluminum one for myself, but you could make a fiberglass one. I used a three inch scat hose from the back of the baffling to the plenum. I used 3/4" aluminum angle to mount the cooler at the top and bottom and used long #10 bolts with compression tubes between the top and bottom flanges of the cooler.
Contact me off-list and I'll send you a picture if I can find it or draw you a sketch.
Jim Crunkleton
N802JD
crunk12(at)bellsouth.net (crunk12(at)bellsouth.net)
