drfred(at)suddenlinkmail. Guest
Posted: Mon Jan 29, 2007 5:59 pm Post subject: Fuel Return |
Eric:
I am still in the wing section and bought the same fittings for the vent
line. Placed them in the left tank and ran the tube 1/2 way down thru
the baffles. That way the return fuel will cool and dump into the
middle of the tank. I'd be glad to send a pic of where I put the exit
if you want one.
Does any body have any information on roll trim? Necessary? Got
asked that question and have not run across any information yet. I know
a lot of the RV 's have heavy wings and require a trim tab on one of the
ailerons. How is that different? When and where should that be
installed?
Fred Williams
drfred(at)suddenlinkmail.com
40515
Tim Olson
Posted: Mon Jan 29, 2007 6:17 pm Post subject: Fuel Return |
With 30 gallon tanks that are pretty long, the -10 sometimes requires
a bit of Aileron trim, and it varies depending on your passengers and
fuel. I've found it much more necessary than on the Sundowner I flew,
because those tanks didn't go out from center as far. Shorter and
longer across the cord. It's a worthwhile option on the -10 though.
Easy to install. just mounts on one wing access plate and moves the
aileron pushrod with a bias spring and servo arrangement.
Fred Williams, M.D. wrote:
Quote: |
<drfred(at)suddenlinkmail.com>
Eric:
if you want one.
ailerons. How is that different? When and where should that be installed?
Fred Williams
40515
GenGrumpy(at)aol.com Guest
Posted: Mon Jan 29, 2007 6:21 pm Post subject: Fuel Return |
I agree with Tim.
Roll trim is a must.
Grumpy
40404 and flying
In a message dated 1/29/2007 8:18:39 PM Central Standard Time, Tim(at)MyRV10.com writes:
Quote: | --> RV10-List message posted by: Tim Olson <Tim(at)MyRV10.com>
Eric:
if you want one.
Fred Williams
40515 |
ron.mcgann(at)baesystems. Guest
Posted: Mon Jan 29, 2007 6:39 pm Post subject: Fuel Return |
Why doesn't fuel management to maintain similar levels in the left and right tank work?
Ron
[quote] From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of GenGrumpy(at)aol.com
Sent: Tuesday, 30 January 2007 12:51 PM
Subject: Re: RV10-List: Fuel Return
I agree with Tim.
Grumpy
40404 and flying
Eric:
if you want one.
Fred Williams
40515 |
Quote: |
| [b]
Tim Olson
Posted: Mon Jan 29, 2007 9:12 pm Post subject: Fuel Return |
I'm not saying that wouldn't help, but whereas some people switch
tanks back and forth a lot, some don't, and I do notice the -10
seems to get a heavy wing pretty easily based on loading
and fuel. So the easiest is just to compensate for both passengers
and fuel. But, you do have a point that proper fuel management
helps to reduce the reliance. I still recommend it though.
McGANN, Ron wrote:
Quote: | Why doesn't fuel management to maintain similar levels in the left and
right tank work?
Ron
[mailto:owner-rv10-list-server(at)matronics.com] *On Behalf Of
*GenGrumpy(at)aol.com
*Sent:* Tuesday, 30 January 2007 12:51 PM
*To:* rv10-list(at)matronics.com
*Subject:* Re: Fuel Return
I agree with Tim.
Grumpy
40404 and flying
requires
passengers and
flew,
> Eric:
for the vent
down thru
into the
the exit
> if you want one.
Got
yet. I know
one of the
be installed?
> Thanks
> Fred Williams
> 40515
