DAVELEIKAM(at)wi.rr.com Guest
Posted: Fri Jan 26, 2007 9:03 pm Post subject: My panel |
Thought I'd post a picture of me sitting in front of my new panel.
(Actually this is compliments of the 128th sim at MKE. I landed it twice in Hawaii and did a full power on stall loaded very lite. What a ride!)
Dave
59.66 KB |
258 Time(s) |
jdalton77(at)comcast.net Guest
Posted: Sat Jan 27, 2007 9:19 am Post subject: My panel |
Dave do you guys plan on flying with out the windscreen, what the hell are
those diving masks doing hanging around in the cockpit.
Either that, you you guys do some pretty silly stuff all alone up front on
those long flights.
If you need some help I can make a referal.
John G.
| Quote: | From: "Dave Leikam" <DAVELEIKAM(at)wi.rr.com>
Reply-To: rv10-list(at)matronics.com
To: "matronics" <rv10-list(at)matronics.com>
Subject: My panel
Date: Fri, 26 Jan 2007 23:02:48 -0600
Dave
| Quote: | << KC-135007.jpg >>
coop85(at)bellsouth.net Guest
Posted: Sun Jan 28, 2007 6:45 am Post subject: My panel |
FWIW, I think the 'diving mask' is actually for use in case of smoke.
United started using something similar awhile back as it was determined the
contents of the smoke could significantly reduce your lifespan in addition
to the benefits of being able to see better.
Marcus
