Automotive Strobes & LED replacement bulbs
richardhughes260(at)yahoo
PostPosted: Fri Jan 27, 2006 11:11 am    Post subject: Automotive Strobes & LED replacement bulbs Reply with quote
Greetings,
I am asking for a friend who is nearing completion of
his airplane.
Strobe sets cost $900
Thee police cares in the Long Island New York area
have strobes in their marker lights.
Is anyone familiar with them?
Any possibility that they could be used in out
aircraft?
And likewise with the automotive LED replacement
bulbs?
-Rich
williamc(at)rv9builder.co
PostPosted: Fri Jan 27, 2006 12:07 pm    Post subject: Automotive Strobes & LED replacement bulbs Reply with quote
Rich,
Check out this site. This may be what you're looking for. I will probably
use one of their strobe kits in my RV.
http://www.strobesnmore.com/
Snip:
I am asking for a friend who is nearing completion of his airplane.
Thee police cares in the Long Island New York area have strobes in their
marker lights.
dennis.glaeser(at)eds.com
PostPosted: Fri Jan 27, 2006 12:16 pm    Post subject: Automotive Strobes & LED replacement bulbs Reply with quote
Rich,
I got my strobe system from www.strobesnmore.com. I'm not flying yet,
but know a number of folks who have automotive strobe systems installed
on flying aircraft. I will be using the Whelen tail light/strobe unit
from Vans. You can also check out www.creativair.com.
If you have interior lighting which uses 'regular' filament bulbs, there
are a number of places that have plug-in LED replacements. LEDs won't
replace landing/taxi lights (yet anyway).
As long as you are putting them on a homebuilt - you can use anything
you want, as long as it meets the appropriate FAA spec, if appropriate,
of course.
Dennis Glaeser
RV7A Fuselage
<richardhughes260(at)yahoo.com
Greetings, I am asking for a friend who is nearing completion of his
airplane. Strobe sets cost $900 Thee police cares in the Long Island New
York area have strobes in their marker lights. Is anyone familiar with
them? Any possibility that they could be used in out aircraft? And
likewise with the automotive LED replacement bulbs?
-Rich
rparigor(at)SUFFOLK.LIB.N
PostPosted: Fri Jan 27, 2006 5:19 pm    Post subject: Automotive Strobes & LED replacement bulbs Reply with quote
Hello Rich
Ain't automotive, Ain't certified, Ain't very expensive:
http://www.kestrobes.com/
I am lookin pretty hard at the Dual Magnum and Combo LED position lights
for Europa project.
Search in arcives if ya wanna listen to the boss man speak of his stuff:
http://www.ultraflightradio.com/
His power supply will drive many heads if ya don't like what he offers.
Not much power draw.
Also too look up install and troubleshooting on his website.
Supposedly the LEDs he uses are way powerful, and by machiningthe base
from aluminium he is able to sink out some of those BTUs.
Ron Parigoris
Hello Rich
for Europa project.
Ron Parigoris
Hello Rich
for Europa project.
Ron Parigoris
bakerocb
PostPosted: Thu Feb 02, 2006 5:33 am    Post subject: Automotive Strobes & LED replacement bulbs Reply with quote
Responding to an AeroElectric-List message previously posted by: John Markey
<markeypilot(at)yahoo.com>
<<Rich, I flew a Vari-EZ with Kuntzelman strobes. They worked great and were
the original
strobes when the FAA inspector signed the plane off for nighttime
VFR.....skip......>>
2/2/2006
Hello John, A common misconception. I will bet that the FAA inspector did
not sign anything that said that airplane was approved as is for night time
VFR. What the inspector signed was a Special Airworthiness Certificate and a
set of Operating Limitations for that specific airplane that was part of the
Special Airworthiness Certificate for that plane.
What the Operating Limitations said was "After completion of Phase I flight
testing, unless appropriately equipped for night and/or instrument flight in
accordance with 91.205, this aircraft is to be operated under VFR, day
only."
This put the responsibility for properly equipping that amateur built
airplane for night time VFR or instrument flight directly into the hands of
the airplane builder. The FAA does not certify amateur built experimental
aircraft for these two conditions of flight because there are no published
certification standards for amateur built experimental aircraft.
This subject has been discussed previously on the list. I have a table that
I will send to any one requesting it that more fully describes the
requirements. That table has also been posted to the web sites of some list
participants. Probably can find where in the archives.
OC
