attaching shielded wires
icubob(at)newnorth.net
PostPosted: Wed Jan 24, 2007 4:03 am    Post subject: attaching shielded wires Reply with quote
hi bob, do you have any illustrated ''how to's'' on attaching shielded wire? i want the shielding to attach also. this is for wiring two p.t.t. switches to the radio.
thanks in advance, bob noffs
glastar(at)gmx.net
PostPosted: Wed Jan 24, 2007 4:55 am    Post subject: attaching shielded wires Reply with quote
Have a look at this one
<http://www.aeroelectric.com/articles/pigtail/pigtail.html>
if you mean about bundling them to one attach point you can use above technique and a ring crimped on the end or as on some equipment (GTX-330) you have a separate bus to end all the shields.
hope it helps
Werner
bob noffs wrote: [quote] hi bob, do you have any illustrated ''how to's'' on attaching shielded wire? i want the shielding to attach also. this is for wiring two p.t.t. switches to the radio.
