Firewall Fuel Fittings
Troy Maynor
PostPosted: Thu Jan 25, 2007 6:54 pm    Post subject: Firewall Fuel Fittings Reply with quote
Hi All,
For those of you that have the classic FWF, and it may apply to XS too, when
you brought the supply and return fuel lines through the top of the tunnel
and thru the F/W, did you immediatly turn 90 deg. upward or straight on
thru? I am ordering some fittings. Need to know if I need straights or 90
deg.after penetrating forward. Mine will be clamped to the top of the
tunnel and going through GS firewall mod.
Troy Maynor
N120EU Europa Monowheel Classic
Left to finish:
Paint,(some) interior,engine install, (some) wiring.
Weaverville, NC USA
winmail.dat
 Filename:  winmail.dat
 Filesize:  1.81 KB
 Downloaded:  156 Time(s)
