taildragon(at)msn.com Guest
Posted: Tue Jan 16, 2007 3:40 pm Post subject: 100LL and TCP |
<?xml:namespace prefix="v" /><?xml:namespace prefix="o" /><![endif]-->
Hi List,
Is anyone running 100LL and TCP in a 912UL? Any problems? How do you get the TCP to mix uniformly with the 100LL. Any problem mixing the 100LL / TCP and mogas that has ethanol?
I recently moved my IV-1200 to a County airport where they are very prejudiced against mogas and encourage using 100LL.
Roger
N499KF
Float Flyr
Posted: Tue Jan 16, 2007 4:44 pm Post subject: 100LL and TCP |
The reasons for using 100 LL for Contis, Lycs and even P&W are well documented.... Your 912 is neither of those and while it can use 100LL in small quantities extended use may damage your engine or shorten your TBO..... use what the manufacturer recommends. You may have to carry your fuel in. Check in your area. It is possible that only the regular grade of gas is contaminated/degraded with Eth.
Just watch the expression of your FBOs A&P when you ask him about the dangers of Ethanol in aviation fuel. What are the bets he answers with one word....."Don't"!
Noel [quote]
_________________ Noel Loveys
Kitfox III-A
Aerocet 1100 Floats |
kitfoxmike
Posted: Tue Jan 16, 2007 4:52 pm Post subject: Re: 100LL and TCP |
I say you can do it, I did all last winter. This winter I went all auto fuel and had no problems at all. Are you in a community hanger? Can you get into the hanger after hours? I would just move the plane out on the flight line and pull your vehicle up to it and put the car gas in it. I use to put it in the airplane in the hanger, generally after hours. I can get 5 gallons from the storage container to the plastic jug to the airplane in about 5 minutes or less.
Bill Willyard
Joined: 10 Jan 2006 Posts: 34 Location: Grandville, Michigan U.S.A.
Posted: Tue Jan 16, 2007 5:39 pm Post subject: 100LL and TCP |
Roger, I have been using 100LL with TCP and Mystery oil for the past year in my 912ul with no problem. The spark plugs show no sign of lead deposits and the oil seems to stay very clean looking as compared to how fast I remember the oil turning dark in my Cessna with out TCP, probably talking apples and oranges here, but just my observation. I simply add the appropriate amounts of both to the fuel tanks after toping off. I figure dispersion and sloshing during the next flight will take care of the mixing. I can't comment on the ethanol part as I have made a point to avoid it and this is the major reason for switching to 100LL.
Bill W.
Classic IV
_________________ Bill Willyard
Classic IV 912UL |
lcfitt(at)sbcglobal.net Guest
Posted: Tue Jan 16, 2007 6:28 pm Post subject: 100LL and TCP |
Roger,
I have used the product John McBean sells on his Sportplane LLC website.
The guys I see using it pours the appropriate amount in the tank before
fueling. I think the thinking is that the fuel flowing in the tank will
give a sufficient mixing.
The stuff John sells is not flamable and is packaged in a squeeze container
that has a measuring feature in it. It works very nicely at the pump.
Lowell
Float Flyr
Posted: Tue Jan 16, 2007 8:09 pm Post subject: 100LL and TCP |
Are the main bearings in the 912 roller bearings like the 582 or slider bearings with babbitt?? I've been told the 100LL will do a number on the main bearings of the little two stroke. Like yourself I'd prefer to use TCP to Ethanol.
Noel [quote]
Kitfox III-A
johnciolino(at)comcast.ne Guest
Posted: Wed Jan 17, 2007 10:29 am Post subject: 100LL and TCP |
Roger,
I have 600 hrs over 10 years on my Model IV-1200 with the Rotax 912UL. I've run 100LL and TCP for 500 of those hours; mogas (without ethanol) prior to that.
I have never had any problems with this combination. My exhaust is a light gray power and the plugs have a light gray deposits on them. The plugs are pretty clean during the annual inspection however, I can find the NGK plugs locally for $1.59 each so I change mine every year and can't comment on the long term affects on the plugs.
I also change my oil and filter every 25 hours and like someone else mentioned the oil is relatively clean. But with only 25 hrs on it that may be the case no matter what gas and/or additive I use. I used Honda mineral based motorcycle oil (i.e. non-synthetic) but have recently switched to Penzoil motorcycle oil.
Bottom line is that I have had no problems in 600 hours. I just jinxed myself.
John Ciolino
N9294Y
Hi List,
Roger
N499KF
Float Flyr
Posted: Wed Jan 17, 2007 12:51 pm Post subject: 100LL and TCP |
Do you use the 100LL straight or with TCP?
Noel [quote]
Kitfox III-A
Bob
Joined: 24 Oct 2006 Posts: 89 Location: Damascus, Maryland, USA
Posted: Wed Jan 17, 2007 5:00 pm Post subject: Re: 100LL and TCP |
John, what a great reply. Straight and to the point on something incredibly relevant.
Thank you very much!
Bob
_________________ Remember that internet advice may only be worth what you pay. |
Posted: Wed Jan 17, 2007 5:34 pm Post subject: 100LL and TCP |
Steve, John, Mike, Dave, Lowell and all the others who responded,
Thank you for your inputs. By far, the weight of the responses say go for the 100LL and TCP with confidence so that is what I will do. This List is great!
Roger
N499KF
Posted: Thu Jan 18, 2007 9:50 am Post subject: 100LL and TCP |
Noel,
I mix TCP with 100LL according to recommended ratio. I use the big syringe Alcor sells which is marked in gallons. I note the number of gals I add to each tank when I fill up and squirt the approrpiate amount of TCP in each tank.
John Ciolino
N9294Y
Noel [quote]
jdmcbean(at)cableone.net Guest
Posted: Fri Jan 19, 2007 9:43 am Post subject: 100LL and TCP |
We also sell TCP that doesn’t need a syringe and is safe to carry in the cockpit. $20 and treats up to 320 gallons.
<![if !supportEmptyParas]> <![endif]>
AUTOTEXTLIST \s "E-mail Signature" <![endif]-->Fly Safe !!
John & Debra McBean
208.337.5111
www.kitfoxaircraft.com
"It's not how Fast... It's how Fun!"
<![endif]--><![if !supportEmptyParas]> <![endif]>
-----Original Message-----
From: owner-kitfox-list-server(at)matronics.com [mailto:owner-kitfox-list-server(at)matronics.com]On Behalf Of johnciolino(at)comcast.net
Sent: Thursday, January 18, 2007 10:49 AM
Subject: RE: 100LL and TCP
Noel,
John Ciolino
N9294Y
Noel
From: owner-kitfox-list-server(at)matronics.com [mailto:owner-kitfox-list-server(at)matronics.com] On Behalf Of johnciolino(at)comcast.net
Sent: Wednesday, January 17, 2007 2:59 PM
To: kitfox-list(at)matronics.com; kitfox-list(at)matronics.com
Subject: Re: 100LL and TCP
Roger,
John Ciolino
N9294Y
Hi List,
Roger
N499KF | Quote: | | <![if !supportEmptyParas]> <![endif]><![if !supportEmptyParas]> <![endif]><![if !supportEmptyParas]> <![endif]> |
| Quote: | | <![if !supportEmptyParas]> <![endif]><![if !supportEmptyParas]> <![endif]>href="http://www.matronics.com/Navigator?Kitfox-List">http://www.matronhref="http://forums.matronics.com">http://forums.matronics.com<![if !supportEmptyParas]> <![endif]> |
[quote]<![if !supportEmptyParas]> <![endif]><![if !supportEmptyParas]> <![endif]><![if !supportEmptyParas]> <![endif]><![if !supportEmptyParas]> <![endif]><![if !supportEmptyParas]> <![endif]> - The Kitfox-List Email Forum - --> http://www.matronics.com/Navigator?Kitfox-List - NEW MATRONICS WEB FORUMS - --> http://forums.matronics.com<![if !supportEmptyParas]> <![endif]>[b]
