pilot4pay
Joined: 01 Jan 2007 Posts: 171 Location: Louisville, KY
Posted: Wed Jan 17, 2007 11:02 am Post subject: Rivet sizing and part numbers |
Please pardon me for these newbie questions. Could anyone clarify for me the dimension referenced for size? For example, when zenith says 5/32" rivet is the dimension reffering to the diameter of the rivet that passes through the material to be fastened?
Is a different size head required for each rivet size to accomodate the difference in stem diameter?
Has anyone had their own riveter head domed, or did you have to buy them?
Does anyone know the textron part number of the rivets? I look at the textron fasteners website looking for a data sheet, but the numbers they use are not simple "A4" or "A5" and their names aren't just Avex, there's Avdel breakstem systems avibulb blah blah blah. I'm just trying to get the data sheets on what will be used in the kit.
Thanks for your trouble.
_________________ Craig Smith
CH640 builder
SN: 0078
"Just think how stupid the average person is,
and then realize that half of them are even stupider!"
--George Carlin |
Carlos Sa
Posted: Wed Jan 17, 2007 1:13 pm Post subject: Re: Rivet sizing and part numbers |
From the archives:
__________________
Match: #15
Message: #5925
Date: Feb 22, 1999
Subject: AVDEL + rivets
Hello Today I called Zenair (in Ontario) and obtained the part number for the rivets: A4 (1/4") 01604-00412 A5 (5/32") 01604-00514
__________________
However, I intend to acquire new batches exclusively from ZAC. It's a long story, but the short version is, you can't go wrong with ZAC rivets.
For the long version, search on "rivets & china".
Cheers
Carlos
CH601-HD, plans
Montreal, Canada
do not archive, it's already there.
_________________ CH601-HD, plans
Montreal, Canada |
bryanmmartin
Posted: Wed Jan 17, 2007 2:24 pm Post subject: Rivet sizing and part numbers |
The stated size is the diameter of the rivet before it is set. The hole
drilled in the metal will be slightly larger (#30 for A4 and #20 for A5)
to allow easier installation. The rivet will expand to fill the hole
when it is set.
You will need a different riveter head for each size rivet for the
reason you stated and because the dome cut in the head will have to
match the size of the rivet head.
Machining the dome into the riveter head is not difficult. I just
chucked the head in my drill and spun it while grinding the dome with a
grinding stone in a dremel tool. Grind a bit, pull a test rivet and
grind some more as necessary to get a good result.
_________________ --
Bryan Martin
do not archive. |
Posted: Wed Jan 17, 2007 2:48 pm Post subject: Rivet sizing and part numbers |
Hi Craig;
Anyone asking questons is an asset! I have had very good results calling ZAC - they always answer very directly.
The aircraft rivet callout always refers to the diameter first and then length - however, I have never used these rivets so do not know if it applies to them as well. The diameter is in 32nds and the length is the grip length in 16ths - usually!
I have attached the PDF for the 1604 fastener (that is what they said it was).
pilot4pay <pilot4profit(at)sbcglobal.net> wrote:
[quote]--> Zenith-List message posted by: "pilot4pay"
Please pardon me for these newbie questions. Could anyone clarify for me the dimension referenced for [url=http://us.rd.yahoo.com/evt=49935/*http://games.yahoo.com]Bored stiff?[/url] Loosen up...
[url=http://us.rd.yahoo.com/evt=49935/*http://games.yahoo.com]Download and play hundreds of games for free[/url] on Yahoo! Games.
 Download |
| Filename: |
avex_1604.pdf |
33.9 KB |
| Downloaded: |
510 Time(s) |
pilot4pay
Posted: Thu Jan 18, 2007 7:21 am Post subject: Re: Rivet sizing and part numbers |
Thanks for all of those who took the time and effort to dig up information for me. I have all the information now. I will need 2 heads for my puller, I can modify them my self, and I have the data sheet for the specific rivet type used. I had suspected it was the 1604, but wanted to be sure, not guess.
Looking forward to this project, just waiting for Can-Zac to schedule the next rudder workshop to get started.
Any other 640 builders out there?
CH640 builder
SN: 0078
--George Carlin |
