lwinger
Posted: Tue Jan 16, 2007 9:02 am Post subject: 601XL flap rib control plate |
Before going further, note that I understand that plans always trump the photo guide. What do you do when even the plans are unclear? I go the the list or call ZAC.
To eliminate my confusion on the size and orientation of the hole (or slotted hole??) on the inboard flap rib (6W1-1), not to mention the orientation confusion between plans and the photo guide, I indeed called ZAC today.
Roger said that actually all that was needed was a 1/4" hole in the rib and control plate, but exact placement was the issue for some builders. His recommendation was to wait until final placement to drill the rib and install the plate. That's now my plan.
For what it's worth.
_________________ Larry Winger
Tustin, CA
Plans building 601XL/650 with Corvair
Installing fuel system
www.mykitlog.com/lwinger |
p.mulwitz(at)worldnet.att Guest
Posted: Tue Jan 16, 2007 10:38 am Post subject: 601XL flap rib control plate |
Hi Larry,
Thanks for posting the information on flap control.
I am just getting ready to install the flap control motor and
associated stuff in the fuselage. My take on your report is that the
actual need for a slot as opposed to a simple hole in the flap rib
depends on how closely the flap control torque tube is located
compared to the piano hinge on the flap itself. The further the
location of the torque tube from the hinge in vertical space, the
more you need a slot versus a hole in the flap rib.
It seems that the slot doesn't do any harm compared to the simple
hole. It allows variation in the location of the torque tube in the
fuselage. This is good since the torque tube is located before the
wing is mounted on the fuselage. Also, the actual flap position on
the wing is delayed until final assembly according to the instructions.
I suppose all this works itself out as you reach final assembly.
Best regards,
Paul
XL fuselage
At 09:02 AM 1/16/2007, you wrote:
| Quote: | To eliminate my confusion on the size and orientation of the hole
lwinger
Posted: Tue Jan 16, 2007 11:20 am Post subject: 601XL flap rib control plate |
Paul,
You are probably correct. As one who is quite a few steps behind you, I don't have the hands-on experience to comment. Just thought the list would like to hear the latest from Mexico, MO.
Larry
[quote] My take on your report is that the
Tustin, CA
davgray(at)sbcglobal.net Guest
Posted: Tue Jan 16, 2007 6:50 pm Post subject: 601XL flap rib control plate |
The most important aspect would be to get both flaps set at the same angle and that there is no binding as the flaps are deployed. If you have any variation from side to side then the actual hole in the drive plate and rib will be slightly different.
The distance between the flap drive pin and the flap hinge pin may vary during deployment and thus the need for a slotted hole to avoid bending the rib. Wait until the wings are mounted and do a few cyclings of the drive pins for the actual measurements with the flaps inserted close to the final position you will be able to visualize where the hole (slot) needs to go.
Gary
[quote] [b]
xl(at)prosody.org Guest
Posted: Tue Jan 16, 2007 10:22 pm Post subject: 601XL flap rib control plate |
Install the flaps for resale, then don't wear them out.
I've landed at Vaughan more than once, no flaps,
(http://www.airnav.com/airport/WN13)
without consequences and turned around about halfway down the field.
Last time, my passenger, a first time 601XL passenger said, 'if you
didn't use flaps now, when would you.' I try to land on the numbers
at BFI, it helps.
Keep in mind, the Zodiac is a light plane, mine is 715 pounds empty.
Flaps in crosswinds weathervane the plane into the gusts.
But, then what the f*%& do I know. Yeah, I had a bad day.........
I should go fly.
Joe E
N633Z (at) BFI
CH601XL, 419 hours, polished (sort of), not a show plane
Jabiru 3300, Sensenich wood prop 64x49
P.S. The above advice does not apply if your airstrip is < 1800 ft.
I don't have experience with that scenario.
lwinger
Posted: Thu Jan 18, 2007 9:07 am Post subject: Re: 601XL flap rib control plate |
Thanks to all for the input and perspective.
Do not archive.
Tustin, CA
