jfogarty(at)tds.net Guest
Posted: Wed Jan 17, 2007 3:13 pm Post subject: RV9a pushrod to aileron question |
I'm trying to get the pushrod to the aileron on the right wing to move smoothly, however, the pushrod is hitting the inboard side of the aft spar where the pushrod travels through the hole. Can I file the hole bigger so the rod and the rivets will not drag and or hit the aft spar?
Thanks.
Jim
gerf(at)gerf.com Guest
Posted: Wed Jan 17, 2007 4:15 pm Post subject: RV9a pushrod to aileron question |
I had to open the hole on mine to get clearance. To minimize the amount you have to bore away, rotate the pushrod so the shop heads of the rivets are the furthest away from closest edge of the hole. Another option is to weld the rod end to the rod rather than riveting it - that eliminates the extra interference issue you have to deal with caused by the rivets.
g
[quote]--
dlawhon(at)yahoo.com Guest
Posted: Fri Jan 19, 2007 4:10 am Post subject: RV9a pushrod to aileron question |
yes thats what your suppose to do there.. because of
the angle the tube travels through the hold..
Danny..
--- Jim Fogarty at Lakes & Leisure Realty
<jfogarty(at)tds.net> wrote:
| Quote: | I'm trying to get the pushrod to the aileron on the
Thanks.
Jim
