Slick Start
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> M14PEngines-List
ScottA
PostPosted: Wed Feb 01, 2006 11:33 am    Post subject: Slick Start Reply with quote
Joe,
I could be wrong but my understanding is the standard booster coil vibrator
works with either mags the M9-F or the M9-35m but the Slick start only works
with the -35m. Which mags do you have?
Scott
- The Matronics M14PEngines-List Email Forum -
http://www.matronics.com/Navigator?M14PEngines-List
ScottA
PostPosted: Wed Feb 01, 2006 11:35 am    Post subject: Slick Start Reply with quote
Just to add to what Dennis was saying I know of one 400hp M14 with -35 mags
that went through two slick boxes because they were getting too hot under
the hood.
FWIW
Scott
dsavarese(at)elmore.rr.co
PostPosted: Wed Feb 01, 2006 11:47 am    Post subject: Slick Start Reply with quote
The standard booster coil will not work with M9-35 mags as they do not have
rotors with two fingers because they are centrifugal advance. Timing on
the -35 mags is set to approx. 5 degrees AFTER TDC depending on the number
stamped in the boss of the mag under the cover. Standard M9-F mags are set
to 14-16 degree BEFORE TDC and have rotors with two fingers in them. One
finger is used strictly for the starting coil.
Dennis
PostPosted: Wed Feb 01, 2006 11:50 am    Post subject: Slick Start Reply with quote
If I'm not mistaken, the Slick system is installed at the P lead. The -35's
with centrifugal advance was/is suppose to replace the starting coil since
the starting coil fired the front plugs from the left mag a few degrees
after TDC the same way the -35's are timed in the first place.
Dennis
ScottA
PostPosted: Wed Feb 01, 2006 12:18 pm    Post subject: Slick Start Reply with quote
That was my impression that the slick system is on the P lead. But I was
also under the impression that the -35 had some sort of interrupter in the p
lead that allowed the standard boost coil to work on those mags too. Of
course just something I read and could have miss-interpreted.
Scott
PostPosted: Wed Feb 01, 2006 12:41 pm    Post subject: Slick Start Reply with quote
The start/booster coil always went into the magneto cap. The purpose of the
P lead is to simply apply a ground to shut down the magneto. Remove the P
lead and the mag will never shut down. That ground goes directly to the
coil and both the -35 and -F mags use the same coil.
Dennis
ScottA
PostPosted: Wed Feb 01, 2006 1:27 pm    Post subject: Slick Start Reply with quote
Ah, I think I get it now. What he meant in the article was that the -35 had
an interrupter in the p-lead that grounded out the mag 100s of times a
second, simulating what the slick start does - if that makes sense, not that
the boost went into the P ground.
It was something George Coy had published.
Scott
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> M14PEngines-List All times are GMT - 8 Hours
