Shut down procedure was RE: Manifold drains
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> M14PEngines-List
ScottA
PostPosted: Wed Feb 01, 2006 11:11 am    Post subject: Shut down procedure was RE: Manifold drains Reply with quote
Ted, do you still run it up a little to help clean off the plugs?  I know you have the auto plugs so maybe not as big of deal?
Scott
From: owner-m14pengines-list-server(at)matronics.com [mailto:owner-m14pengines-list-server(at)matronics.com] On Behalf Of Ted Waltman
Sent: Wednesday, February 01, 2006 12:01 PM
To: m14pengines-list(at)matronics.com
Subject: RE: Manifold drains
I have a clean kit on my engine, which enables me to completely drain the sump after shutdown, so I don't have to spend a min at 50% or so power before shutdown.
- The Matronics M14PEngines-List Email Forum -
http://www.matronics.com/Navigator?M14PEngines-List
tedwaltman(at)i1ci.com
PostPosted: Wed Feb 01, 2006 11:18 am    Post subject: Shut down procedure was RE: Manifold drains Reply with quote
I've never run it up just before shutdown.  I do get a bit of oil on the rear plugs, it seems, esp after 10 to 14 days if I haven't run it, but the mag drop on the rear in this case is not too excessive.  Seems to clear right out after the run up and not be a noticeable problem re power during that initial T.O..
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> M14PEngines-List All times are GMT - 8 Hours
