Manifold drain lines all down hill
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> M14PEngines-List
ScottA
PostPosted: Wed Feb 01, 2006 10:51 am    Post subject: Manifold drain lines all down hill Reply with quote
Another question on the manifold drain lines.
I made sure mine all went “down hill”, no place for oil to pool.  I know most are not this way, the drain is above the low spot.
Does it really matter?  Can it suck in the little oil left in the line?
Scott
- The Matronics M14PEngines-List Email Forum -
http://www.matronics.com/Navigator?M14PEngines-List
dsavarese(at)elmore.rr.co
PostPosted: Wed Feb 01, 2006 11:01 am    Post subject: Manifold drain lines all down hill Reply with quote
Yes, it can.  But that small amount of oil will not cause the cylinder to hydraulic lock.
Dennis
tedwaltman(at)i1ci.com
PostPosted: Wed Feb 01, 2006 11:03 am    Post subject: Manifold drain lines all down hill Reply with quote
I believe the deal is to just get the oil (or too much fuel in a primed--too-much scenario) out of the cylinders to prevent hydro-lock.
ScottA
PostPosted: Wed Feb 01, 2006 11:26 am    Post subject: Manifold drain lines all down hill Reply with quote
Thank yet again Dennis.
Good to see you here, hopefully more CJ/YAK and Pitts12 types will find and use this list too.
Scott
From: owner-m14pengines-list-server(at)matronics.com [mailto:owner-m14pengines-list-server(at)matronics.com] On Behalf Of A. Dennis Savarese
Sent: Wednesday, February 01, 2006 12:01 PM
To: m14pengines-list(at)matronics.com
Subject: Re: M14PEngines-List: Manifold drain lines all down hill
Dennis
KJKimball(at)aol.com
PostPosted: Wed Feb 01, 2006 5:38 pm    Post subject: Manifold drain lines all down hill Reply with quote
Ted,
The amount of oil in the 1/4" drain kit line low spot is very small.  On the order of what you can hold in a soda straw with your finger on top of it.  We have actually removed the line you refer to and have found the amount of oil to be about 1/3 of the total internal volume of that hose.  Just a few Cc's.
Sincerely,
Kevin Kimball
VP Engineering
Jim Kimball Enterprises, Inc.
PO Box 849, 5354 Cemetery Rd.
Zellwood, FL 32798
407-889-3451 phone
407-889-7168 fax
http://www.jimkimballenterprises.com/
http://www.pittsmodel12.com/[u]
[/u]
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> M14PEngines-List All times are GMT - 8 Hours
