Serial input transponders?
a.s.elliott(at)cox.net
PostPosted: Mon Jan 15, 2007 7:07 pm    Post subject: Serial input transponders? Reply with quote
Gang:
I am planning a minimalist glass cockpit, and find that my EFIS will output serial altitude data directly. Anyone have a list of which transponders will accept serial input?
I know that the Garmin GTX-327 does. What about the -320A? What about any of the new NARCO boxes? Becker? Microair? Others? (Keep in the in range of $2000± GA units. I know that the fancier $datalink$ units all do.) The serial-Gillman converter is about $250, which gives me some lattitude in selecting a slightly pricier serial-compatible unit.)
Andy Elliott, Mesa, AZ
N601GE (reserved)
601XL/TD/QB, Corvair, building...
wgill10(at)comcast.net
PostPosted: Mon Jan 15, 2007 8:13 pm    Post subject: Serial input transponders? Reply with quote
Dr. Elliott,
Negative on the 320/320A. Dynon produces a serial-to-parallel converter if that helps.
Bill
N1DeltaWhiskey(at)comcast
PostPosted: Tue Jan 16, 2007 12:59 pm    Post subject: Serial input transponders? Reply with quote
The Apollo SL70 does, if it is still available.
Doug Windhorn
