Wiring Diagrams Design Software
BigD(at)DaveMorris.com
PostPosted: Tue Jan 03, 2006 1:30 pm    Post subject: Wiring Diagrams Design Software Reply with quote
After installing and trying many different ones and throwing them all out,
I finally found DesignWorks Lite from Capilano Computing for $39.95. I
bought it a few years ago and have never looked back. It works intuitively
the way a CAD program should. You can design your own components if the
switch or relay or gadget you need doesn't exist in one of their libraries.
Here's a schematic I did with it:
http://www.davemorris.com/Photos/Dragonfly%20Electrical/N75UP-Schematic-June2005.pdf
Here's their web site: http://www.capilano.com/
I highly recommend it for ease of use in drawing schematics. They have a
free trial. I think it's better than any of the other options I've heard
people mention so far.
Dave Morris
At 10:04 PM 12/29/2005, you wrote:
Hi all ...
How many OBAM electricians have used the PC based software to draw their
wiring diagrams?
I'm interested in finding out what you have found and reccomend, don't
recomend, like alot or any comments about they are easy to use or not easy.
Or is all the PC based stuff a waste of time?
I see some on ebay, new ones, outdated programs, cheap and not one bidder
... why is that?
Any help appreciated ... thanks alot,
Jerry Grimmonpre'
Dan.Beadle(at)hq.inclines
PostPosted: Tue Jan 03, 2006 4:10 pm    Post subject: Wiring Diagrams Design Software Reply with quote
I don't see where SL12 goes from the crowbar. Is it supposed to be
SL-5? There must be a breaker somewhere that kills the dynamo.
SL-9 also is a dangling label. I assume there is a switch to ground to
serve as the battery master. Sounds like you open that switch to kill
the right main bus, then close the E-Bus feed. Seems like a DPDT might
work better - up for normal, down for e-bus, center for OFF. (simpler
pilot workload).
