Fat Capacitor Question
mjurotich(at)hst.nasa.gov
PostPosted: Sun Jan 14, 2007 6:35 pm    Post subject: Fat Capacitor Question Reply with quote
I am thinking of putting a Fat capacitor between the E bus and ground. Idea is
if the E bus switch is open
and the battery is suppling power through the diode
and the voltage sags for a short time (300 milliseconds is what I
remember) when first engaging the starter
the capacitor would keep the voltage above 10 for the voltage
sensitive stuff that may reset.
2 questions:
Would this work?
It seems to introducing a single point failure for the shorted
capacitor case. Are todays electrolytic caps sufficiently robust to
mitigate the risk?
Matthew M. Jurotich
e-mail mail to: <mjurotich(at)hst.nasa.gov>
phone : 301-286-5919
nuckollsr(at)cox.net
PostPosted: Mon Jan 15, 2007 6:59 pm    Post subject: Fat Capacitor Question Reply with quote
ground. Idea is
the capacitor would keep the voltage above 10 for the voltage sensitive
2 questions:
Would this work?
Sure. In fact it's been done. The quick-n-dirty design
tool takes notice of the fact that a 1F capacitor discharged
at 1A will fall at 1V per second. So, assuming the system you're
protecting draws 3A. Assume further you want to keep the voltage
from falling below 10v with a start from 12v. Assume further that
you want to support the device for 1/2 second.
A/F = V/S
3/F = 2/0.5
3/F = 4
F = 0.75 Farads
That's a FAT capacitor. You can buy 1F caps popular with the
folks who like to install ear-crusher audio systems in their
vehicles. See:
http://tinyurl.com/tvrtx
The capacitor can get small by reducing supported
current, reducing support-time or allowing a greater voltage
drop during inrush transient.
If your system will benefit from some form of transient isolation
system, I think you'll find that a small battery is a much better
energy storage device. The smallest of SVLA batteries can be isolated
from the rest of the system during a few seconds of cranking time.
The installed weight and volume will be smaller but there will be
a preventative maintenance issue for the AUX battery. In this case,
AUX battery capacity is not a big issue ASSUMING that its only
task is to mitigate cranking inrush brownout. This means that you
could run it until it fails to support the protected system.
I've used some FAT caps for similar tasks but they have some
special integration issues. You can't just hook these critters
to a battery to charge them . . . charging currents are very
high and tends to burn switches. You need to develop a special
current limited charging circuit to avoid the stress.
Super caps are going to REPLACE batteries in our airplanes
in the foreseeable future. But using a FAT cap to replace
a small sealed lead-acid battery in this application is
problematic.
< with experiment. >
< --Lawrence M. Krauss >
