jesse(at)itecusa.org Guest
Posted: Sat Jan 13, 2007 5:00 pm Post subject: Powder Coat quality |
Has anybody else on the list seen this type of quality on the powder-coated parts?
By the way, this is our solution to the axle spacer problem, without the flats yet. AN5-6A bolt through the axle nut too.
Do not archive.
Jesse Saint
I-TEC, Inc.
www.itecusa.org
Cell: 352-427-0285
Fax: 815-377-3694
35.24 KB |
158 Time(s) |
nandrand(at)xtra.co.nz Guest
Posted: Sat Jan 13, 2007 11:43 pm Post subject: Powder Coat quality |
Hi. Looks as if the metal has not been prepared properly, should be dipped to remove grease,cutting fluid etc. Send it back, tell 'em to do it right.............
Regards & Fly Safe Noel
